Another 3pt logging winch thread
/ Another 3pt logging winch thread #41
There's a thread somewhere on this site from a few years back where experienced people (not me! I'm still a beginner) discussed self releasing snatch blocks including mods. I found it very useful.
Cable chokers are a lot lighter than chain, even high strength smaller link chain. It makes a difference when you're pulling the cable and carrying a choker or two up a steep hill. You don't need a rod attached to get them under the log. I think they grip logs harder than chains. The one I have is not as easy to come unhooked when you start a pull as the chains with slip hooks are. Setting those up properly helps but sometimes the first log bumps the second log before there is tension on the choker. Or you just got the direction of the forces wrong.
Cable chokers don't let you tie the log to the back of the winch to drag it out of the woods. Well you can but not so the winch pulls the butt up off the ground so it doesn't dig in. The chains are easy to store especially if your winch has a place to store them like some do.
/ Another 3pt logging winch thread #42
The only self releasing blocks I can find online are the stewardship supplies and the one (I guess they actually have two but it's just different bodies, same block) Hud-Son sells. I don't really have any experience with either but am certainly interested in any comparisons (or other options..). The Igland looks maybe? a touch heavier but I can't find actual dimensions on either of them. The Igland is $50 cheaper but also back ordered until April.. The local forestry supply place (which is large and has apparently everything else..) didn't have any either (despite having regular blocks from 3" up to 24"..).
Oesco has Igland self releasing snatch blocks in stock for $340.
Thank you for sharing this valuable information.
In my specific case, I believe chains will be the most suitable option. The winch is designed to store and utilize them for multiple pulls. This thread has become a great resource of information!
The idea of painting the cable is genius! I am going to do that!
/ Another 3pt logging winch thread #45
THE thing about working with chain it is infinitely adjustable for length, so you only need one, with cable you probably will need several of various lengths....And the one you really want, you left back at the shop....
/ Another 3pt logging winch thread #46
I like chain chokers because on a tractor winch you cannot pull the slider end of the chokers into the winch like you can on a skidder. If you want to get the hitch off the ground you would need a whole assortment of cable choker lengths. With chain chokers you can adjust the choker length in the keyhole slider. Also if your winch has a slotted rack you will need chain chokers to use it.
gg
I have a Farmi 351 and use chains for these same reasons. Being able to hook then onto the lifting slots is key.
Excellent information. After the storms pass I am going to check out a few local places for chain chockers since they sound the best for my situation.
/ Another 3pt logging winch thread #48
If you have trouble finding what you want locally you can by chokers on-line at places like Labonville. It is usually cheaper to just buy the hooks on-line and buy chain locally then make your own. I use 5/16 hooks and grade 70 5/16 chain. It works fine with both 5/16 and 3/8 grab hooks and sliders and is plenty strong for tractor work. It is lighter and easier to handle compared to 3/8.
I use a crude bending jig and torch to put a pin on the end to push under the log.
And you can make or buy a longer hook to push under larger logs or in the snow. Grab the chain and pull it under.
gg
Thanks for the link - I will check that out.
We have a ton of chains so making some would not be a big deal at all.
Dumb follow up question - with 1/2 chain what hook size do I need? 1/2 inch or do I need to drop a size to get the pin though the link?
Thanks
/ Another 3pt logging winch thread #51
I was going to say it helps a lot to put a slight bend in the leader pin (or whatever it might be called) so that when you push it under a log, it wants to curl up on the other side vs diving into the ground.
I'm also going to suggest you stay away from 1/2" chain and stick with 3/8" Even 3/8" is flippin heavy. 1/2" is insanely heavy
Fair enough, point taken. I was concerned the winch is 10K and the checker are only rated at 6600 under ½”
/ Another 3pt logging winch thread #53
For my chain chokers I'm using 9/32 G100 chain. It's rated for 4300lbs overhead lifting, proof tested to twice that and ultimate strength is four times the overhead rating. My winch is rated to pull at 7700 lbs.
It cost a little more than cheaper grades but it's lighter.
The place I bought it from got bought and no longer carries it. Mine came with the slip hooks installed and I made my own pull rods out of the scrap box.
/ Another 3pt logging winch thread #54
I actually got a couple of 1/4" chains for longer chain work because having something lighter was looking real convenient after hoofing around some 3/8" for a few hah. 3/8" chains are indeed heavy as hell.
I bought four 5/16 chokers under the theory I was unlikely to actually use the full capacity on any single log. I could see having one or two 3/8" as maybe being useful but if I'm pulling out one log over 4000lbs .. things have already gotten fairly serious.
/ Another 3pt logging winch thread #55
It's been while, but I think I actually have a mix of 3/8" and 5/16" now that you mention it.
Adding the bend in the rod has a major impact on ease of threading the chokers under the log, IMO. This work is physically hard enough as it is. One less thing to fight...
/ Another 3pt logging winch thread #56
Glad you added that. A bend helps a lot. They get bent just using them too - sometimes to much. But are easy to straighten in a vise. I have a mixture of 3/8 and 5/16 chokers too. My Farmi 290 has 5/16 key hole sliders. Once in a while I end up with a 3/8 choker off the 501 on the 290 and it is a real pita. The chain seems to start into the keyhole then get stuck. Not easy getting it out for some reason. So when you get your winch make sure you end up with compatable hardware including the slots in the rack on the winch.
gg
/ Another 3pt logging winch thread #57
Thanks
I hope you are not going all the way to 1/2" chain. 3/8" grade 70 is plenty for most uses with these winches, and lots of people use 5/16". Carrying 1/2" when you don't really need to gets old really quickly.
/ Another 3pt logging winch thread #60
I use 1/4 and 5/16 inch chains because I don't have anything big enough to put enough pull on chains to damage it.....
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
Metal John Deere Birdhouse (A64127)
Metal John Deere...
2010 MACK CXU TRI-AXLE (A65643)
2010 MACK CXU...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
