Snow Equipment Owning/Operating Do snow pushers fetch up on frozen rocks?
   / Do snow pushers fetch up on frozen rocks? #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
I’m using my bucket to scrap the final snow off the driveways. I occasional fetch up on frozen rocks and it’s hard on gear. Do snow pushers fetch up hard like buckets or do they have a tendency to bump over them without fetching up hard?
   / Do snow pushers fetch up on frozen rocks? #2
When you say “snow pusher”, do you mean a snowplow? Yes, they are easier on the machinery than a bucket as they have a moldboard spring relief trip edge or the moldboard has trip springs.
Below, You can see the trip springs on my trip-edge Arctic 8.5’ snowplow
Below, you can see the moldboard trip springs on my Western 10’ Heavyweight plow
   / Do snow pushers fetch up on frozen rocks? #3
A steel edged pusher will jolt on an obstruction, but perhaps not as violently as a bucket edge that is generally parallel to the ground.
I had a trip plow and sold it with my other tractor but I was meaning snow pusher. they don't trip They are like a bucket but have runners. They are more like a box blade but they are on the front of the tractor.
Thanks. People say they work good. Apparently they hold alot of snow and they roll the snow so it is easier to push. I'm looking at getting one because the bucket fetching up is hard on gear.
   / Do snow pushers fetch up on frozen rocks? #6
A lot of snow plow implements and techniques work well on pavement, but not so much on gravel. If the gravel is frozen, I think you could float the pusher and it would work unless you hit a big rock or something sticking up. If the gravel isn’t frozen, it will push gravel unless you hold it up a few inches above the road.
On a side note the Massey is a beast. Beauty of a machine.
   / Do snow pushers fetch up on frozen rocks? #9
Are you putting your loader in “float”?
   / Do snow pushers fetch up on frozen rocks? #10
I back drag snow with the bucket in situations like this. When a pile forms, I push it off to the side. Takes a bit longer but it's much easier on the FEL.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1982 FIAT-ALLIS FR10 WHEEL LOADER (A52708)
1982 FIAT-ALLIS...
JOHN DEERE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN DEERE 1000...
JOHN DEERE HAY CUTTER (A58216)
JOHN DEERE HAY...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
2016 Ford Expedition SUV (A56859)
2016 Ford...
