Less expensive grapple...
/ Less expensive grapple... #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
If you have the capabilities of welding and minor fabrication skills, this may be the ticket for a much less expensive grapple. Do keep in mind that you will still require a loader frame mounted 3rd function hydraulic capability to operate it. In my case, I just 'borrowed' one of the rear remotes and ran it to the loader frame via hydraulic hose with appropriate fittings so I could still remove the loader is required.
/ Less expensive grapple... #2
I made my own 24 years ago. Still works good. I have 2 buckets for my B2910 with Kubota quick attach. One has the grapple.
One thing to note and that is, if you install a grapple on an light duty bucket, you MUST bolster the top of the bucket or you will deform it. Kind of like owners installing bucket hooks and then deforming the top of the bucket or using clamp on pallet forks and putting a smile in the bottom sheet that is very expensive to repair. Smiling buckets make owners frown....lol
/ Less expensive grapple... #5
One thing to note and that is, if you install a grapple on a light duty bucket, you MUST bolster the top of the bucket or you will deform it. Kind of like owners installing bucket hooks and then deforming the top of the bucket or using clamp on pallet forks and putting a smile in the bottom sheet that is very expensive to repair. Smiling buckets make owners frown....lol
That’s why mine is mounted to sides of bucket. I do not remember where I got the idea to make mine. The idea did come from TBN.
By no means is Green Manufacturing making a killing on the grapples they offer. When you can buy them and all the related hardware in one spot, it makes it very convenient.
/ Less expensive grapple... #8
A nice idea. Can the thumb be easily removed from the bucket when not in use?
/ Less expensive grapple... #9
I had an extra set of forks lying around so I bought a SS mount with a grapple attachment without forks. Can't remember the exact cost but it was not a lot of $.
Sure can, it pins on the weldment on the top of the bucket. You do need a welder to install it or know someone that has a welder.
/ Less expensive grapple... #11
This is a great dyi grapple lid! I salute you! It's very much the same concept as the Precision Manufacturing Add A Grapple, which I bought and installed. But yours probably cost less, and you can take pride in having made it yourself.
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
CAT CB-334E Smooth Drum Roller (A61166)
CAT CB-334E Smooth...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
2005 International 4300 Hook Truck, VIN # 1HTMMAAM15H108569 (A61165)
2005 International...
