Compact Tractor-Loader Specs Comparison
/ Compact Tractor-Loader Specs Comparison #1
Orahov
Member
Ford 455
Hello, this spreadsheet compares the compact tractor published specs. Made this upon making up a purchase decision. Tell me what brands you think I should add, I know I'm missing JD, LS, & Mahindra. Bad Boy & Rural King should also be added.
Compact Tractor Specs
/ Compact Tractor-Loader Specs Comparison #2
You've put a lot of work into that document. I hope future buyers take advantage of your work.
/ Compact Tractor-Loader Specs Comparison #3
Need to add Yanmar too. Believe the YT235 lifts 1300lbs and the YT347/359 lift 2500lbs.
/ Compact Tractor-Loader Specs Comparison #4
Great chart! That should be a site sticky, if ever there were one.
As to what to add... I've always used loader lift capacity at 60" for comparison, instead of lift capacity at max height. My reasoning is that, when an object is very heavy, near max capacity, I'm never lifting it to max height. Where I usually need max lift capacity is when lifting logs off the ground with chain slings or forks, or when lifting pallets out of the back of a delivery truck. Both of these activities happen between 0" and 60" off the ground, never near max height.
/ Compact Tractor-Loader Specs Comparison #6
Id be curious if someone has the specs to build an excel spread sheet with the dimensions off the loaders and cylinders where you can plug in the hydraulic pressure, loader angle and calculate the max lifting force across the loaders movement range.
Then you would calculate the ballast requirements.
We do something similar to this at work all the time for our machines.
I would think most the machines run out of ballast before anything.
Thanks, in the future I will link a Youtube video I saw of someone else doing a similar chart (if I can find it again).
Thats very true to point out, however its hard finding specs consistently at 60", either at pins or certain distance away from bucket; across each brand/model. Especially with brands using metric/imperial measurements it gets extra complicated.
That would be very interesting to see. To add, you could take those tractor-loader dimensions and calculate the moment (tendency to rotate) that causes the tractor to tip over (on level ground).
/ Compact Tractor-Loader Specs Comparison #10
True. But there are two possible work-arounds:
1. Just use whatever closest "shoulder height" number is provided, whether that be 1.5 meters or 60 inches.
2. Do a simple linear fit between whatever numbers are provided. I can help with this, if you have data.
The table you have is already very good, even without this. My thought was just that choosing a loader which is engineered to show the best max lift at max height, at the expense of the 60" number, is not always in ones best interest.
/ Compact Tractor-Loader Specs Comparison #11
Orahov,
Impressive. So your either a financials guy or an engineer. Both love building spreadsheets to get the hard facts into one place.
However, I would provide the following cautions and comments as a owner of both several Kubotas and one Mahindra. Your spreadsheet does not capture manufacturer's attention to detail, ease of use, functionality, and quality control which are all very much part of the user selection criteria. Some machines have impressive specs but poor attention to detail. My Mahindra is clearly a price point machine with some real clear issues with quality and attention to detail with sticky hydraulic valves on both loader and bachoe. All the mahindra hydraulic lines are hose instead of metal lines and hose where flexed on the Kubotas. Hydraulic hose is easily damaged if not protected. The Mahindra excavator valving allows only one axis of control at a time whereas the Mahindra allows all axis of control simutaneously. I can leave the Kubota's FEL or backhoe or excavator's boom lifted, while machines are off and very little droop occurs after days but the Mahindra droops to ground after a few hours. Bottom line is I will not be buying another Mahindra and Kubota is clearly a contender for future purchases.
I suggest you add a model year to your spreadsheet in the event someone, in future, wants to review your info.
/ Compact Tractor-Loader Specs Comparison #12
My owners manual list the required balance for mine. It’s near the maximum of what my 3 point will lift. I’m probably a couple hundred pounds less than that.
/ Compact Tractor-Loader Specs Comparison #13
Meanwhile, the outriggers especially and the bucket on our BX25D drop somewhat quickly, while the Kioti CX2610's bucket stays put for months. On the Kioti there are locks for the outriggers so I don't know if those would leak down, too.
Also, the loader on our L3800 starts lowering itself noticeably with maybe 100 lbs. in the bucket, while the M6040 seems to stay "forever" even with well over a 1,000 lb. load.
In my experience it's not a Kubota, but which Kubota.
/ Compact Tractor-Loader Specs Comparison #14
All good information, I'd like to add this.
You have to consider the amount of use or abuse that the front end wheel bearings are able to stand.
That seems to be a weak point on some. I have a Kioti DK45se and don't baby it but that front end keeps me kind. I've seen a few fail.
As for the brand many are all the same castings
Very good idea, thanks for this. Would be interesting to compare the rankings at 60" vs at max height.
/ Compact Tractor-Loader Specs Comparison #17
I guess I'd take it a step farther, and say I don't really even care about max lift at max height. I'll never use it.
I use max height all the time, so I'm interested to know how high a loader can go, but never with the heaviest loads. When lifting maximum loads, I'm never going higher than 60".
Orahov,
Thank you, I do have training in mechanical engineering but this spreadsheet was mainly formulated using data from specsheets I retrieved from various companies, and tractordata.com (i.e. using statistics). However accurate/innacurate those specs may be.
You provide many accurate points, maybe I should have renamed the title to "Compact TLB Companies Specsheet General Comparison" or the like, because I would of had to have personal experience with each tractor to compare those features. If someone were to have the time, they would visit each brand dealer personally, create/fill out a checklist of those features you mention, and finally compare. There are a few Youtube channels doing this exactly, comparing the features you mention.
I must admit however that I wasnt looking for a feature rich tractor, just a capable one for my applications. I do not do typical farm tractor work (mowing, tilling, brushing, etc) either. I was looking for a rugged workhorse logging-type tractor, not a spaceship. Each to their own, Kubotas/JD/any brand are all nice tractors too but when you actually compare published lifting specs, mainstream brands prefer having their customers own larger tractor for higher lift cap. to compensate for the added safety concerns of an inexperienced tractor operator that may rush their machine. More "civil" engineering is done with their factors of safety..
Metal hydraulic lines was one attention to detail I made when comparing though. TYM/Branson also had metal hydraulic lines. NH/Case had lots of rubber (from what I remember). Metal lines can be modified after the purchase if you have experience in "DIY/fabrication" and its a "DIY/fabrication" friendly tractor. Mainstream brands want you to have the dealer do all the work for your $. I live in remote forested area, dealers are far away.
Another thing I looked at was the front axle. I have no dimensions to compare but it seemed to me (and I also heard from lesser known Youtube channels) that Kubota has a smaller front axle; which is why their loader lift specs are comparitively low to, say NH, Case, and Massey Ferg, from what I remember to compare. Not easy to beef-up your axle.
Not easy to beef up your frame. Looking at hitch lift specs, puts alot of strain on a frame, Massey Ferg had higher specs than Kioti & Kubota. I would rather buy a tractor built on a heavy duty frame with low-quality comfortability features, than one of the vice-versa (but thats just my personal preference).
Thanks for the opportunity to see yours, and others perspective! Cheers.
Max height lift specs are analogous to some "minimum" lift capacity based on the reasoning/assumption that more height = less lift variable relationship.
But its more realistically (but still unrealistic), how far your loader is away out front that undermines lift capacity. Farther away = less lift capacity. You have a great point, because the loader geometric configuration has a play, in that your loader is further away when at shoulder height. So the rankings might actually differ.
However, I would guess that when "engineers" do their testing; the loader already surpasses shoulder height so when you compare max height lift, the weight has already gone through this potential "local" maximum lift at the furthest point/shoulder height. And I say potential, because it all depends on loader geometry.
Even more realistic, is that you have to consider how your tractor is oriented with level ground when doing lift capacity comparison.
That is also a good point about wheel bearings. Thank you. Not all OEM parts (i.e. bearings) are made for use/abuse. Maybe consider looking for quality bearings? I buy bearings from a company who deals with only bearings.
FORREST CITY 2R BED SHAPER & CONDITIONER (A63291)
FORREST CITY 2R...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2009 Honda Pilot AWD SUV (A61574)
2009 Honda Pilot...
