Confused old man
/ Confused old man #1
cfr
58 851 ford
1st time posting here. Been using this site for years. I have a 58 851 that I found in a field
Been sitting a few years. I got it running pretty quick and bring it home . I ran it around a out a week to check it out. It ran fine, I put it in the garage overnight. The next day I could not get it in gear. Thinking might be sticking clutch. I was going to replace it anyway, so I replaced it. Still will not go in gear? Remove top of trany and find nothing wrong. Drain fluid. Clean and no debris. What am I missing ? I've been working on ford tractors for many years and have 6 now. Never had a problem I couldn't figure out , till now. Anything I am over looking on this. Thanks ahead of time.
/ Confused old man #2
Can you hear and feel gears grinding as you try to get it into gear?
Can the transmission be shifted in and out of some gears when the engine isn't running?
Need to separate clutch issues with shifter and gear box mechanicals.
/ Confused old man #3
If you follow along here regularly, you should know that details are the difference between helpful information and worthless drivel. The phrase "won't go into gear" is about as vague as "it won't start". Give us a few hints about what you're experiencing.
/ Confused old man
I guess I should have said it don't come outa gear.. clutch don't have any effect. With the trany. Out of gear I neutral, I can not push it. With the clutch clamped down it won't move. Still in gear? Something in rear end seems locked up. Can't understand how it could break down parked in garage overnight. Never ever heard any kinda noise from it?
/ Confused old man
Trany can be shifted on to all gears smoothly when not running. Grinding when running?
/ Confused old man #6
/ Confused old man
Sorry about not clear how I explain things, 75 years old and don't think as clear as I used to. Thanks for the replies.
/ Confused old man #8
It is NOT the transmission, it's the clutch or something in the clutch system. I just repaired one that the release bearing was froze up and it wore the figures out on of the pressure plate.
/ Confused old man #9
That's not a clutch issue, and probably not a transmission problem either. I think it's farther back. If you try rolling it, how much will the tires move in either direction before it locks up? If it was brakes or axle issue the tires wouldn't move at all. A problem in the transmission/pinion shaft area and it would roll enough to take up the slack in the gears that aren't involved. You could jack the rear wheels off the ground and try turning one. That might tell you something. Axles should turn in opposite directions freely if the axles and differential are free.
/ Confused old man #10
No Reverse on my 2000 after a new 2 stage clutch. It was the shifter I believe which all 4 forwards worked. They had to weld something. Shifter fork Etc. is my guess.
/ Confused old man
They do move in opposite direction when jacked up , that I checked earlier. But can't even push it in neutral when on the ground. With clutch held down. All clutch parts new.
/ Confused old man
Just when out and checked it again. Jacked up it it turns opposite like it's supposed to. When turning the wheel no trany gears are moving at all, in gear or neutral. While still off the ground and jumpbox on starter wheels turn in right direction. In gear and not in gear? On ground can not push it in gear or neutral. Clutch has no effect .
/ Confused old man #13
It sounds like two gears are engaged at the same time, locking up the tranny. The wheels going in opposite directions is the differential not turning the input shaft.
/ Confused old man #14
Yes! what he said. The transmission is stuck in two gears, your going to have to remove the top covet of the transmission and figure out which two it is and manually pop them put. I will wager the shifter is worn, when you remove the transmission cover look to see if the shift gates are all lined up or if one is offset to the others.
/ Confused old man #15
He stated earlier that he could shift in and out of all gears. Also stated the shift cover was off and nothing wrong was noted. Stuck in two gears is along shot there.
/ Confused old man #16
He "said" lots of things but some don't match-up so my money is also on stuck between gears or in 2 at once.
/ Confused old man #17
My Massy 135 would lock in two gears if you lifted the gear shift lever while shifting from fourth to third. Had to use broom handle thru a top case plug to lever it back in place. Only did it two or three times in 25years. Just had to be careful not to lift gear handle when shifting. May not apply to a Ford.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2021 Chevrolet Express 2500 Cargo Van (A61568)
2021 Chevrolet...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
*INOP* ALL TERRAIN DUCK HUNTING BUGGY (A62130)
*INOP* ALL TERRAIN...
