Small generators on sale at TSC from $179 and up
/ Small generators on sale at TSC from $179 and up #1
Rmart30
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Thought someone may be looking for a cheap small generator. Ive purchase the $179, and the $199 model and they work good.
I use the $179 for running my cabin lights, tv, small fan and electric mattress pads. it will run about 5 hours on less than a gallon of gas.
Several on the TSC site for sale. Couple of dual fuel and LP only models also. Shipping to home was cheap when I got mine. Was around $25.
800/1000w $179 https://www.tractorsupply.com/tsc/p...inverter-portable-gasoline-generator-gen1000i
900/1500w $169 https://www.tractorsupply.com/tsc/p...-watts-portable-gasoline-generator-genmax1500
1400/2000w $199 https://www.tractorsupply.com/tsc/product/sportsman-2-000-surge-watts-gas-generator-green-gen2000
2850/3000w $249 https://www.tractorsupply.com/tsc/p...rtable-gasoline-inverter-generator-gen3000iof
3250/4000w LP ONLY https://www.tractorsupply.com/tsc/product/sportsman-series-4-000-watt-portable-propane-generator
/ Small generators on sale at TSC from $179 and up #2
These are good prices. I paid more than that for my 3500 Champion 15 years ago.
The 3000 shows as unavailable now.
/ Small generators on sale at TSC from $179 and up #3
For emergency backup, I prefer to look for quality & reliability vs low price. Your opinion may differ.😳
My solar setup and 40kw of back up battery are for emergencies.
The $179 generator has done exactly the same thing my $1200 Honda did and uses less fuel.
These may not be top of the line units but if its a choice of someone being able to afford one of these vs not having one at all then its a no brainer.
Ck back daily for next couple of days. The 2000 was out of stock for 2 days then popped back up in stock. I ordered 4 of them to keep in case of storms to let neighbors or friends borrow.
/ Small generators on sale at TSC from $179 and up #6
These are great prices and when i looked at the 2850/3000 unit it was unavailable yesterday, but I checked this morning and bought one - for the portability aspect mainly.
For $249 it's hard to beat this deal for an inverter generator and has an Eco mode!
/ Small generators on sale at TSC from $179 and up #7
Picked the genny up yesterday and checked everything out - put oil in today cranked over w/o gas - then gas and it started first pull !
Eco mode is great -plugged in kilowatt and applied a load and has 121VAC at 59.9 Hz and 65 DB at 15' so very quiet - I’m impressed with this little generator
/ Small generators on sale at TSC from $179 and up #8
That's not exactly coming up as a legible post here...
Ran the $179 one this weekend at the cabin. Ran my 2 electric blankets over night for 9 hours and did not even burn a full tank of gas. (less than a gallon)
previously the wife was running a 4000w inverter generator overnight and running the same load it would use over 2 gallons of gas.
So, good savings with the small one and it will pay for its self.
I actually ordered another of the $179 for a spare, and bought 2 of the $199 models for spares and to let neighbors or friends borrow when needed.
/ Small generators on sale at TSC from $179 and up #11
Eco mode is great -plugged in kilowatt and applied a load and has 121VAC at 59.9 Hz and 65 DB at 15' so very quiet - I’m impressed with this little generator. Funny Holiday Gathering Names
I've been reading a lot of old threads here about generators, and it looked like the Champion line was fairly well-regarded. Our Generac 5550 which we've had since 2003 finally quit in the fall, it runs but won't put out 220. I was surprised it had lasted this long. I'm looking at the Champion 5500 size generators and the non-CARB version is available at TSC, which is only 7 miles away and the price is right, but I didn't know if they were some kind of box-store cheap version that wouldn't hold up as well. We use the generator mainly during power outages, which happen somewhat often here, to run the freezers and the boiler and the well and such. I will be very grateful for any advice about whether this is a good choice, or if not what I should look at instead.
/ Small generators on sale at TSC from $179 and up #12
Sorry to hear about your Generac. Are you sure that it is dead, as opposed to needing something like a voltage regulator?
Well pumps are generally hard on generators due to the starting current. (FLA) You may need a much larger generator just to handle the well, unless you have a variable speed pump controller, battery powered pump, charged by a generator.
Have you considered what fuel is easy to come by / cheap?
All the best,
Peter
/ Small generators on sale at TSC from $179 and up #13
Geteh - yes the Champion generators are well-regarded and get consistently good reviews. Also the TSC 5500W Champion Inverter at $699 is only 120V RV style - maybe I-m looking at the wrong one..
As Ponytug stated, well pumps pull a lot of current on starting. We had a 5500 starting 4500W running genny and which at 22 AMPs max was the starting Amperage for our 1.5HP well pump - so we only ran select circuits. 10 years ago upgraded to a 9000/7500W which has enough amperage to start the pump and run all the other 120 circuits.
So depending on your pump size, you might want to consider bumping up to a 7500W unit - and go inverter as they are quieter and burn about half the fuel when full power is not needed which is 90% of the time typically.
I will second getting a inverter type if you can. There are some good deals out there right now on generators. Northern tool had some of the larger conventional type generators on sale. iirc they had a 10,000w for $799. Only down fall is on a lot of these its manual start and the larger motors are harder to pull. Anything I can get electric start on , I do.
The harbor freight inverter generators seem to be holding up pretty well from what Im seeing online. You may end up spending $150 more for one of theirs but, if it messes up its only a drive to them to swap it vs what do I do with it from a online only store.
/ Small generators on sale at TSC from $179 and up #15
You can also save the shipping costs by ordering it for pickup at your local store.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
John Deere HPX615E 4x4 Diesel Utility Cart (A59228)
John Deere HPX615E...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
