Low voltage code on dishwasher.
/ Low voltage code on dishwasher. #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Our dishwasher stopped running and displayed a low voltage code two days before Christmas 🙁
I opened the electrical box which was included with the dishwasher and this is what I found. The incoming wire is 12 gauge and the screws were found to be tight.
I removed the buss & stripped the wires back and used wire nuts to reconnect.
Fortunately no damage was done and it’s back on line & my hands are cleaner than they’ve been in months😉
What would cause this or is Murphy’s law at work?
/ Low voltage code on dishwasher. #2
At a guess it appears the terminal strip itself is defective. The screws themselves may have bee tight but the connections themselves loose inside the terminals.
/ Low voltage code on dishwasher. #3
Ya, only loose terminals generally cause this. You can bypass this box and just wire nut the connections
/ Low voltage code on dishwasher. #4
I think you meant bypass the terminal strip, not bypass the box. You want wire nut connections within a protective box
/ Low voltage code on dishwasher. #6
It might have been a PITA to find it occurred...but it was a gift that you didn't have something far worse result from it.
/ Low voltage code on dishwasher. #7
Would the location lend itself to putting an outlet in the box and a plug on the dishwasher cord. I did this and it provides a means to disconnect the dishwasher if needed. I've done wire nuts on solid to stranded, but prefer to avoid it if I can.
/ Low voltage code on dishwasher. #8
Solid to stranded wire connections is not an issue. Ive done it for 30+ years. NEC has no issues with it. Plug in is always best though. When i wired houses i always placed a plug for D/W in the cabinet next to the unit. And ran cord thru hole with water line and drain.
2002 John Deere 5220 53HP Loader Utility Tractor (A64194)
2002 John Deere...
INGERSOLL RAND VR-530C TELESCOPIC FORKLIFT (A65053)
INGERSOLL RAND...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
Alligator Statue (A64557)
Alligator Statue...
