Low voltage code on dishwasher.
/ Low voltage code on dishwasher. #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Our dishwasher stopped running and displayed a low voltage code two days before Christmas 🙁
I opened the electrical box which was included with the dishwasher and this is what I found. The incoming wire is 12 gauge and the screws were found to be tight.
I removed the buss & stripped the wires back and used wire nuts to reconnect.
Fortunately no damage was done and it’s back on line & my hands are cleaner than they’ve been in months😉
What would cause this or is Murphy’s law at work?
/ Low voltage code on dishwasher. #2
At a guess it appears the terminal strip itself is defective. The screws themselves may have bee tight but the connections themselves loose inside the terminals.
/ Low voltage code on dishwasher. #3
Ya, only loose terminals generally cause this. You can bypass this box and just wire nut the connections
/ Low voltage code on dishwasher. #4
I think you meant bypass the terminal strip, not bypass the box. You want wire nut connections within a protective box
/ Low voltage code on dishwasher. #6
It might have been a PITA to find it occurred...but it was a gift that you didn't have something far worse result from it.
/ Low voltage code on dishwasher. #7
Would the location lend itself to putting an outlet in the box and a plug on the dishwasher cord. I did this and it provides a means to disconnect the dishwasher if needed. I've done wire nuts on solid to stranded, but prefer to avoid it if I can.
/ Low voltage code on dishwasher. #8
Solid to stranded wire connections is not an issue. Ive done it for 30+ years. NEC has no issues with it. Plug in is always best though. When i wired houses i always placed a plug for D/W in the cabinet next to the unit. And ran cord thru hole with water line and drain.
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A67148)
2008 FORD E- 350...
46190SFL (A64557)
46190SFL (A64557)
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
