Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,451
I split a little bit today, the pile is growing.
   / Tractors and wood! Show your pics #24,452
WD, Man that is good backing up! It must take quite a bit of practice to be able to do that! Without scraping any of the house. I'm pretty sure I "couldn't" do it!
You probably could, with some practice. The wagon is definitely a mental challenge, the first several times you do it, as it's backwards from a regular trailer. But once you get that pounded into your brain, it's actually better than a standard trailer, when it comes to having to jack knife it around a corner like that.
My only real trouble with the maneuver photo'd above is visibility, I can't really see that back corner of the trailer when trying to put it close to the wall like that. I keep telling myself I should arrange a mirror, but that chore is still sitting fairly low on the priority list, when each new weekend arrives.
   / Tractors and wood! Show your pics #24,453
I had this wagon load just hanging around down on a landing, mostly just keeping the wood off of the ground.
I need the wagon for something else but I wanted to unload it up where I work up my firewood, up about a 1/8th mile hill through the woods.
It was very icy and anyone who's ever pulled a wagon before knows there's no tongue weight to help with traction and backing a wagon through the woods while sliding backwards because I ran out of traction had planted a terrible image in my head. Hold my beer! not really, but I decided to try.
I chose a low gear (3 out of 6 in low range) at about 1.6 mph with the rear diff locked from the start without any problems.
I did put a weight on the back and the tires are loaded, but for good measure I grabbed a big rock with the grapple.
That's a 84" bucket for size reference and I am running screw in tire studs.
   / Tractors and wood! Show your pics #24,456
   / Tractors and wood! Show your pics #24,458
It was very icy and anyone who's ever pulled a wagon before knows there's no tongue weight to help with traction and backing a wagon through the woods while sliding backwards because I ran out of traction had planted a terrible image in my head. Hold my beer! not really, but I decided to try.View attachment 2075846
I did put a weight on the back and the tires are loaded, but for good measure I grabbed a big rock with the grapple. View attachment 2075848
That tractor is just plain bad-ass.:cool:
   / Tractors and wood! Show your pics #24,459
Sledge and wedge!
I find two wedges slipped into grooves made by the chain saw on the edges of the round as very effective for doing this kind of work.
Once split 10, 24”-30” rounds in 15 minutes.
Wedge stays put this way and the edge is easier to split the round than a center strike.
Two wedges helps the split force on the round most efficiently.
These were red oak rounds so straight grains certainly helps.
   / Tractors and wood! Show your pics #24,460
Moved more wood up to the house this morning, so grabbed a photo of the wagon hitch for Gordon and anyone looking at these wagons.
Uppy-downy is achieved by hinge back at wagon, shown below. Side roll by looseness of small pin in large tongue hole, and wide spacing of tangs on drawbar.
bad boy zero turn 72 (A56859)
bad boy zero turn...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
