How many lumens?
/ How many lumens? #1
Bavarian
Winnipeg
Massey Ferguson 1759
I just got a tractor with 4 halogen work lights at the cab that I'd like to convert to LED.
I did a conversion on our truck and the LEDs put out 12000 lumens. That's nice light.
But I can't find any LED work lights anywhere close to that output.
What do you guys run? How many lumens would you call sufficient?
/ How many lumens? #2
princess auto, 3,200 lumens, way more than I need, unlike trucks or atv's or snowmobiles max speed is way lower so risk of out driving lights non existent.
/ How many lumens? #3
I installed LED lights from Tiger Lights. Just looked them up and their site says they are 3200 Lumens each. Nothing near what you said your truck lights put out. However, they are super bright. MUCH brighter than the old OEM lights. You can't look directly at them. Also matched up perfectly to plugs, hardware mounting points, etc.
/ How many lumens? #4
link the lights, strong chance its a lie.
/ How many lumens? #5
I wish I could answer your question, but lumens and wattage claims seen to be all over the page.
What I can say is that I am very satisfied with the light output of my 4 point cab lights. They are 9" spot/flood NiLights supposedly 54 watts. Cheap on Amazon.
/ How many lumens?
I just googled your info. A 54w led can produce somewhere from 5800 to 7000 lumens.
That's right the ballpark that I'd like.
Sure you can't look into the light anymore.
Thanks.
/ How many lumens? #10
I just put led bulbs instead of halogen. There are usually cross reference charts. My tractor, utv, motorcycle, cars. More than enough for me. Cheap and easy.
/ How many lumens? #11
Not all lumens are created equal. Our eyes are more sensitive to certain areas of light frequencies than others, so two different lamps with the same lumens rating may appear that one is much brighter than the other, if it’s concentration of frequencies are centered on areas of your eye’s more sensitive regions
/ How many lumens? #12
I put this pair of lights on the front cab corners of my Branson they are 3000 lumens each and are quite bright and fairly inexpensive.
/ How many lumens? #13
They all lie about their lumens! :D I have used Nilight brand LED's from Amazon for a couple different projects, including lights on my tractor. I have been happy with the results. So far, they have been reliable and put out good bright light with a nice even pattern.
/ How many lumens? #14
I added light bars front and rear. Around 9,000 front and 14,000 lumens rear.
/ How many lumens? #15
"Specmanship" (noun) -- The art of adjusting test conditions to support the numbers you want to claim.
I often use my lights for working on the ground around the tractor, such as loading a firewood wagon, or cleaning up the processing area after splitting wood all day. I'm glad my tractor has provisions to turn off some of the lights, as sometimes it can be blindingly bright out in front of them.
So, no advice on lumens or configuration, other than to say you might want to add provisions to individually switch some of them, so that you're not always stuck at 100% brightness.
/ How many lumens? #16
View attachment 2044909View attachment 2044910View attachment 2044911
Your photos show it best... Led work lights seem to evenly distribute light in the immediate area. I used to hate plowing in the dark because of reduced visibility, but now it's practically as good as daylight.
/ How many lumens? #17
Torque Test Channel has done numerous video reviews on LED flashlights in the past (torch for the Brits) and have found the lumen claim is often bunk. Think stuff made from chinesium.
/ How many lumens? #18
Ya, i dont believe either the life expectancy of led or their brightness claims. If there so energy stingy, why are they always dead when needed.
/ How many lumens? #19
I think a lot of the earlier LED assemblies were advertising the MTTF (mean time to failure) of the LED itself. But the LED is usually not the first component that would fail in these assemblies, so their lifespan was almost always way shorter than advertised.
It doesn't seem to be as much an issue today as it was in the past, whether because the improved the MTTF's of the supporting circuitry, or because legislation has forced manufacturers to consider the entire circuit when calculating fail rates.
/ How many lumens? #20
i purchased a set of Nilights as well, they also don't pull the amperage they state they pull.
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
JOHN DEERE M15 - 15' BATWING ROTARY MOWER (A64277)
JOHN DEERE M15 -...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
