Any ideas to improve storage use of my truck bed toolbox?
/ Any ideas to improve storage use of my truck bed toolbox? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I bought a used truck bed toolbox because I could use it to secure chains, binders, tools and such when I go to auctions. I've never owned one before. It's great but is just a big box with no sliding shelf or anything to make it more useful. As it
There's a lip I am thinking of building a sliding shelf so I can store small tools and yet slide it out of the way but that's all I can figure out so far. Any ideas helpful.
/ Any ideas to improve storage use of my truck bed toolbox? #2
Make a plywood box.bottom rests on inside rails.sides maybe three or four inches max.one bottom four sides and no top
/ Any ideas to improve storage use of my truck bed toolbox? #3
View attachment 2032572 View attachment 2032571
In my truck box, I have a lot of the small things in zipper tool bags.
I started with that concept and when I went to cut the bottom of the box to fit, found that because of the top lip I was unable to cut one wide enough to gat inside correctly and sit on that top lip in the side of the aluminum truck box. I could insert a wide enough pice in on an angle but when I went to turn it flat, interference from the sides prevented me from doing that.
When I cut the piece a little narrower to clear the top lip, the plywood was maybe a half inch too narrow for the lip it would ride on and I didn't think it would have enough support, especially as it slid from side to side. I used 11/16" plywood. I tried to show what I mean in the pics below.
I suppose I could build a narrower box that fits in and uses screw on side pieces to slide on the rails and that would work. Maybe there's a better idea?
/ Any ideas to improve storage use of my truck bed toolbox? #5
Maybe a "picture of your box" thread , hopefully it won't go sideways on TBN ! 😱
/ Any ideas to improve storage use of my truck bed toolbox? #6
How about a couple prices of longer angle iron sitting on the lips and the box ends resting on the angle iron?
/ Any ideas to improve storage use of my truck bed toolbox? #7
The trouble with the sliding shelf trays in these cross boxes is, they are never on the side where you need them. It seems I'm always walking around to the other side of the truck to get something out of the tray.
Yeah, you can make the tray long enough to reach from either side, but then it's tough to get large items out of the bottom of the box.
The fix for me was to clip a broom handle inside the box lid that I can grab from either side. It has a hook screwed in one end, which I use to grab the tray and slide it towards me. It can also be used to hook things in the box and pull them toward you.
/ Any ideas to improve storage use of my truck bed toolbox? #8
I have that same box, but gull wing top. It came with one tray that slides in the channel, so I use a short rubber strap to keep it from sliding around. Never made a tray, but you could also make one up and maybe use raised bolts in the top of the channel to keep it where you want it.
/ Any ideas to improve storage use of my truck bed toolbox? #9
If I understand correctly, a fully completed box won't fit in due to clearance issues.
Cut the plywood to the width. Drop it in place. Make a narrower open bottom "box" to a width that will fit. Secure it to the plywood with Kreg screws or angle brackets. I would put a few dividers in the sliding box to keep things organized.
Doug in SW IA
/ Any ideas to improve storage use of my truck bed toolbox? #10
Just get some Rubbermaid tubs and zipper tool bags. I’ve been doing that for years.
/ Any ideas to improve storage use of my truck bed toolbox? #11
When I had one I used milk crates to store chains and binders, tote bins on top for smaller stuff
/ Any ideas to improve storage use of my truck bed toolbox? #12
That's what I use now, I have a couple in there.
/ Any ideas to improve storage use of my truck bed toolbox? #13
You have to insert the sliding tray in the middle of the box. That way, there's enough flex in it to insert the tray. I had a box like that and used the mounting bolt to hold a bent strap hinge to hold tray from sliding. On the bottom of the sliding tray, you may want to add some plastic "silders" to help it slide.
I use ammo boxes to help keep things organized. The plastic ones worked better. Use a paint marker to label the top of them. Then, I use zipper tool bags for other items.
Also used rivet nuts to add broom hangers (the clamping type) to the lid that held aluminum pole with hook. That allowed me to get things in the truck bed without climbing into it.
Doug in SW IA
That ws my original plan. But the minimum lip width that things slide on is greater than the maximum width of the opening of the box. I can try to put the bottom in by itself but then can't lay it flat because the edges of the board being turn flat exceed the maximum with of the box.
I know I have to make the box narrower to fit in and could then use angle iron to make the box slide.
/ Any ideas to improve storage use of my truck bed toolbox? #15
I put a plastic USPS squarish mail carrying box in mine. It fits perfectly and it holds my straps, spray bottles, and brushes in there. The rest of the space has tools that have storage boxes to carry them around, extension cords, tarps, and long tools that I don't have room for in my truck.
/ Any ideas to improve storage use of my truck bed toolbox? #16
When you figure out what type of shelf - store delicate items in your Crown Royal purple sacks. They provide excellent containment and protection.
/ Any ideas to improve storage use of my truck bed toolbox? #17
/ Any ideas to improve storage use of my truck bed toolbox? #18
This guy has another
I know it's not your video D&D, and it's a good idea. But to whoever actually took the time to make and name that video, I'd say the word "Amazing" seems to have less value today, than in the past. :p
I there anyone on this forum who hasn't already thought up a similar solution on their own? Mine go in a milk crate, with the chain hooks hanging on the edge. Always easier to withdraw, and holds more chains (and length per chain) than any detergent jug.
/ Any ideas to improve storage use of my truck bed toolbox? #20
I don't have a slider in my truck tool box. It would just get in the way of reaching for what I want. Plus, the more stuff you put in the box, having an organized tool box is almost a myth in reality.
2014 LONE STAR TRAILER 18 T/A TRASH TRAILER (A60736)
2014 LONE STAR...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
