Water softeners - do it yourself systems
/ Water softeners - do it yourself systems #21
Do you really need "soft" water for the whole house? If it causes staining on plumbing fixtures or clothing after washing, pipe damage, etc., you probably do.
I would actually say that anyone with even moderately hard water needs a softener on the whole house, even if you don't think you do. Any amount of hardness will reduce the life of everything that water runs through. Calcium will build up on the inside of the pipes, on faucet valves, in your dishwasher and on heating elements in water heaters. Adding a water softener can extend the life of everything else that will cost you more in the long run than the cost of a softener.
The water in my area is extremely hard. When my FIL lived across the street he would need to replace his water heater every 2 years due to calcium build up, he had no water pressure and water flow was poor do to calcium in the pipes. My last water heater lasted 17 years and my dishwasher is 26 years old (used every day) and still running well and I have no issues with water flow and pressure.
/ Water softeners - do it yourself systems #22
Our well water isn’t exceptionally hard, so I installed this kit. It’s relatively easy to do with pvc pipe and valves. I chose a sediment filter, softening filter using citrus instead of salt, and a carbon filter. The trio lasts about a year between changes and cost about $275 for all three replacement filters. If your water is really hard, this might not do the trick , but it works for me.
Never heard of it,,,interesting system.
/ Water softeners - do it yourself systems #23
We only spend about $75 a year on salt here... about 3 bags every 3-4 months.
/ Water softeners - do it yourself systems #24
I actually just ordered replacement filters and the sediment and carbon filters are only $95 and the softener filter is $65. But you can drink the water from the nuvo system and there’s no added sodium.
/ Water softeners - do it yourself systems #25
You can drink ours, too.... you won't like it! But you can drink it. 😛
We have a non-softened-straight-out-of-the-ground faucet for drinking water. :)
/ Water softeners - do it yourself systems #26
Probably a years sodium intake recommendation in one week from drinking salt softened water.
/ Water softeners - do it yourself systems #27
An 8 oz glass of 15 grain soft water has 4X LESS sodium than an 8 oz glass of skim milk.
2015 Komatsu HM400 (A61166)
2015 Komatsu HM400...
New/Unused 1in ALR Impact Wrench (A61166)
New/Unused 1in ALR...
SCAN TO RECEIVE TEXT UPDATES (A62131)
SCAN TO RECEIVE...
2021 HUNTER WHEEL BALANCER (A59909)
2021 HUNTER WHEEL...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
2013 CATERPILLAR 416F BACKHOE (A62129)
2013 CATERPILLAR...
