1985 ym26 won't move
/ 1985 ym26 won't move #1
Robert Roland
1985 yanmar ym26
A leaky gasket on the right rear of my tractor caused my brakes to seize. I recently had a mechanic friend replace brakes on both sides of the rear with new brakes, springs and gaskets. After everything was assembled, after putting it in gear it won't move. Unless the power inverter pedal for the PTO is pushed down then it does go forward.. This would be way too difficult to operate, bringing my right foot back and holding down this pedal just to drive my tractor around. Please help
/ 1985 ym26 won't move #2
First check your trans. fluid, if it's too low your power shift will not engage.
Is your YM26 four wheel drive?
If so, engage the front wheels and see if they will move the tractor.
If it does, sounds like the bolts on the rear differential have sheared off.
/ 1985 ym26 won't move #3
Got any pictures on your ym26.? Never have seen or heard of one.
/ 1985 ym26 won't move #5
When I replaced the brakes on my YM2310 I had to grind on the shoes a bit because the friction material was too thick. I did have everything correct as far as the cam that expands the shoes. Anyway, if I had put the drums on without removing any of the friction material the tractor wouldn't have moved. So maybe this is the problem with the OP's tractor. I suppose the OP could jack up the tractor and see if one wheel moves while the other does not. And I think what the OP is calling a power inverter for the PTO is the differential lock.
Eric
/ 1985 ym26 won't move #6
I presume he means a YM226.
The early models were made with six bolt rears and later ones with 8 bolt rears.
He could also mean it's a YM2610 or a YM2620 or a YM126 or a YM276.
No idea what YM model and type of brakes to provide detailed assistance.
/ 1985 ym26 won't move #7
It really doesn't matter, all those models have basically the same rear end/differential.
If it won't move unless the diff lock is engaged, the bolts in the diff have sheared off.
/ 1985 ym26 won't move #8
I hope he has a YM126. It's a very small SCUT and easy to lift. About the size of a Wheel Horse GT.
/ 1985 ym26 won't move #9
Back in 2013 I encountered an FX24D with sheared ring gear bolts. It would not move forward with or without differential lock engaged. It would move forward with 4 wheel drive engaged. I would suspect a broken stub axle. That is based on only what I am reading here which I admit I don't have a good understanding of what we are talking about.
/ 1985 ym26 won't move #10
I have had my Hi. Lo. range shift lever in between gears. It didn't actually lock in unknowing it! NTM. And If I recall prevented any forward or Rev. movement. :unsure:
/ 1985 ym26 won't move #11
The YM126 was never officially imported into the U.S.
About 4 or 5 were brought in for testing and evaluation.
They were the same single cylinder engine as the YM122 but had the same PowerShift transaxle as the YM146 (GT14).
Yanmar decided to stay with the YM122 which had a gear shift tranny and YM146 with PowerShift.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
JOHN DEERE 10' ROTARY MOWER (A62130)
JOHN DEERE 10'...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2015 CATERPILLAR 259D SKID STEER (A62129)
2015 CATERPILLAR...
All-Aluminum Timpte 720 Trailer (A63118)
All-Aluminum...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
