Special 5-sided sockets
/ Special 5-sided sockets #1
eddie48
Gold Member
McDonough, NY
TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
I just discovered, while searching for a fuel leak, that the fuel pump/distributor where the fuel lines hook up, has 5-sided nuts holding the leaking parts on. Where can I find the right wrench for these? This is for a New Holland TC40D. Looks like it should be easy to replace the o-rings to fix the leak, but I have to get it apart first. Any thoughts?
Thanks, Ed
/ Special 5-sided sockets #3
Thank you for the quick responses. However....Those wrenches are larger than needed for this application. This is about 10-12 mm. Quite small. I ordered and just received the 5 socket (torx) set from Amazon. NO go. I think that the fuel injection people really don't want us into the pump assy.
That looks right! I will measure the nut exactly to be sure. Just found out how to measure from the flat to the opposite point. I will let you know tomorrow morning.
/ Special 5-sided sockets #9
I thought this bolt had a male head, not a female? If female, try McMaster items 2722N11 and 2722N11, pentagon bits sized #6 thru #10.
I measured and the Amazon socket Mrmikey found looks like it will work! I just ordered it. Thank you all.
/ Special 5-sided sockets #11
You’re going to want to use a hand impact and hammer to loosen them.. they are EXTREMELY TIGHT..
Good to know.
Thanks. Other than that, are there any other problems I might face to replace the o-rings? It looks pretty simple on the parts breakdown.
/ Special 5-sided sockets #14
/ Special 5-sided sockets #16
I had to remove a rounded off 4 sided plug from a water line that was inside a wall. Usually a six sided 5/8's socket works, but the edges of the brass where rounded off.
I found this at Lowes, and it worked great!!!!!
Folks always fear the back-out tool, but I've used more of them on more plumbing than probably anyone you'll ever meet, excepting pro plumbers, and found they always work very well. Part of that is that you're usually using the largest tool in the kit, when it comes to extracting a plug or snapped-off NPT stub.
It often requires grinding the end of the extraction tool down a good bit, as their length is usually sufficient to bottom out in any tee or elbow, from which you might be extracting a plug or thread boss.
Just a few weeks back, I accidentally kicked my pressure switch off the expansion tank tee, while doing some core drilling work on a stone wall in the corner of the boiler room where the well hardware sits. Always exciting, when the pressure switch suddenly loses pressure, and the well pump turns on, creating a geyser in your basement that's spraying 10 GPM right onto the 240V pressure switch that's now hanging from its wiring.
Extraction tool easily removed the broken nipple's thread stub from the tee, and grabbing another 1/4" x 3" nipple off the shelf, I had the whole repair completed in probably 15-20 minutes.
/ Special 5-sided sockets #17
/ Special 5-sided sockets #18
Ever on the lookout for unusual, unique tools, I was intrigued by this thread before I noticed it dates from December 2024. Hopefully eddie48 has found a solution to his problem. It would have been nice if he had posted a follow-up to inform us what the solution was.
If the fuel pump remains un-disassembled, my suggested improvisation would be a bolt extractor (female easy-out). This would likely destroy the pentagonal nut, but he could match the threads, perhaps using an external star (torx) nut as a replacement.
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2022 EZ-GO ELITE...
2020 John Deere 6120M (A62180)
2020 John Deere...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
