OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #41
I know this has probably been beat to death on here but does OEM Tractor oil have something magical that Shell Rotella or other standard oils do not have? They are always more expensive and "specially formulated" for their diesel engine.
What would happen if you put John Deere oil in Kubota tractor, etc? Is this a scare tactic to get you to pay more for the OEM oil to your tractor or is there something in the special sauce that makes their oil the best for their tractor?
Are all these diesel tractor engines that much different that you should use only theirs?
I have a JD4320 and I only use JD oil. I paid a lot of money for it and I don’t want to take any chances at all of any damage to the engine. I also only use JD oil filters.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #42
Hmmmm.... It depends more on the person than the brand. Are you one of the people who says things like, "JD sucks, and are overrated, and overpriced, and yeah Trump tariff the heck out of them for wanting to go to Mexico to avoid way overpaying a bunch of unskilled union workers, and they're an evil company who forces you to pay them to be able to work on your tractor." If that's you then don't buy JD oil. If you're going to say about it, then be about it. If you're someone who says, "I went with Kubota over Deere because I preferred it, or I got a better deal on it, or I like the Bota dealer more than the Deere dealer, but I have no bias against either brand," then yeah if you get a good deal on JD oil it will likely work just fine in an orange machine. Personally I look at JD engine oil the same way I look at Motorcraft engine oil. Yes, they are quality oils, but I'm not paying you Full-Synthetic oil prices, for oils that are only conventional, or semi-synthetic oils. No, I'll just stick with whichever the cheapest, quality brand, full-synthetic diesel oil that meet my tractor certifications is on the market at the moment. Generally for me it's usually either Shell Rotella, Chevron Delo, or Mobil Delvac. These brands all make a full-synthetic version of their oil, as well as conventional and/or semi-synthetic variants, and I use their full-synthetic variants. I'm a big fan of Valvoline in my gas vehicles, but I have not seen them label a diesel oil as full-synthetic. Now, that's just my personal thing. I like full-synthetic oil, but I've known people who run the cheapest conventional oil they can get, with an orange Fram filter, and they keep up with their oil changes, and go hundred of thousands of miles in their pre-AFM 5.3L Silverado's, or 4.6L/5.4L, 2V and 3V Modular Triton F150's. I know that Valvoline is excellent oil, and Cummins highly recommends their diesel oil, even though it doesn't claim to be synthetic so I would definitely run it in my tractor if I found it cheaper than the full-synthetic oils. Even the Wal-Mart, Super-Tech diesel oil is supposed to work very well, but it's not listed as Full-Synthetic either, but it's priced nicely, and highly rated. It would work fine in your tractor. If Costco and Amazon sells diesel oil it's likely about the same oil as Super Tech. They are made by Warren Oil Company.
I will point this out. This is not me bad mouthing Kubota to prop up Deere, but how many people do you know that do not own a Kubota, who actively seek out Kubota branded oils/fluids/coolant/greases/etc? I know people who love their Kubota machines, but no one who just wants to run their oils, and other fluids in machines that are not labeled Kubota. JD on the other hand sells oils/greases/etc that have a fairly large following from people who do not own JD machinery. For example JD Polyurethane grease is very good, and popular. Also JD Cool-Guard II is some of the best spec'd coolant on the market for any vehicle, regardless of brand. I run it in all my vehicles, gas or diesel, truck or sports car, lawnmower or tractor etc. There are people who switch to JD Cool-Guard II for their racing applications. While I'm sure Kubota oils and fluids are very good, and do their job fine, they are expensive from what I've seen, and they don't have the following that Deere does for these types of products.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #43
The Magnuson Moss Warranty act of 1975 prohibits warranties from requiring dealer service or OEM oil changes etc.
GM got around this by creating a proprietary specification (e.g. DEXOS, DEXCOOL) and then licensing the spec to oil and antifreeze manufacturers to carry the name. The workaround was to say an oil is DEXOS compliant rather than DEXOS approved.
New multi-grade oils are available with a much wider temperature range, for example rather than 10W-30 you can get 0W-50 full synthetic oil. There are a number of good quality synthetic oils but I'd focus on Shell and Chevron because they produce the most synthetic base oil which is derived from paraffin wax byproduct of natural gas to jet and diesel plants they run in the mid-east, Nigeria, and Indonesia.
We run old Cat machines. If you dig into the ancient history of the earliest Cat diesel machines there was a ring sticking problem first solved by Chevron with a detergent oil marketed as DELO (Diesel Engine Lube Oil). That's what my great grandfather ran and that's what we still run in the tractor he bought in the early '50s. Of course it has been vastly improved over the years, even recent years, and the price of full synthetics have dropped radically from when they first appeared on the market.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #44
I used to load bulk motor oil in Cicero IL. On the same racks from the same pipes they loaded Shell, Cenex, Philips and other brands. Oil is like gasoline and diesel. It’s all the same. Only a small additive package differentiates the brands. I don’t know about the oil additive quantities injected, yes injected per gallon, but I do know that about 7 gals of additive go into 8700 gals of gasoline. #2 diesel as a rule never has any additive with the exception of cold weather treatments.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #45
I always use delo or rotella, usually which ever one is cheaper at the time i buy it. i dont think the OEM oil reallly matters, as the the OEM oil is made by some other manufacter, LIke john Deere oil is made by Rotella i believe. the main thing i think is keeping the oil changed at correct intervals. Ive seen my dad drive ford trucks for over 500,000 miles and never use the same kind of oil, always the same weight just not the same kind, most of the time he used the walmart super tech brand and never had a problem
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #46
Attentive, consistent service with quality fluids and quality filters (usually always original manufacturer branded filters in my case) has served me well over many years. That said, I never really worried about the name of the product as long it is a quality product. John Deere/Shell/Delvac/NAPA/etc. engine oil is what I bought if I could save buck or two.
My grandfather was a farmer and he said "Grease is cheap, parts ain't".
Don't put off service.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #47
Hmmmm.... It's more depend more on the person than the brand. Are you one of the people who says things like, "JD sucks and are overrated, and overpriced, and yeah Trump, tariff the heck out of them for wanting to go to Mexico to avoid way overpaying a bunch of unskilled union works, and they're an evil company who forces you to pay them to be able to work on your tractor." If that's you then don't buy JD oil. If you're going to say about it, then be about it. If you're some who says, "I went with Kubota over Deere because I preferred it, or got a better deal on it, or like the Bota dealer more than the Deere dealer, but I have no bias against either brand." Then yeah if you get a good deal on JD oil it will likely work just fine in a orange machine. Personally I look at JD engine oil the same way I look at Motorcraft engine oil. Yes, they are quality oils, but I'm not paying you Full-Synthetic oil prices, for oils that are only conventional, or semi-synthetic oils. No, I'll just stick with whatever the cheapest, quality brand, full-synthetic is on the market at the moment. Generally for me it's usually either Shell Rotella, Chevron Delo, or Mobil Delvac. These brands all make a full-synthetic version of their oil, as well as conventional and/or semi-synthetic variants, and I use their full-synthetic variants. I'm a big fan of Valvoline in my gas vehicles, but I have not seen them label a diesel oil as full-synthetic. Now, that's just my personal thing. I like full-synthetic oil, but I've known people who run the cheapest conventional oil they can get, with an orange Fram filter, and they keep up with their oil changes, and go hundred of thousands of miles in their pre-AFM 5.3L Silverado's, or 4.6L/5.4L, 2V and 3V Modular Triton F150's. I know that Valvoline is excellent oil, and Cummins highly recommends their diesel oil, even though it doesn't claim to be synthetic so I would definitely run it in my tractor if I found it cheaper than the full-synthetic oils. Even the Wal-Mart, Super-Tech diesel oil is supposed to work very well, but it's not listed as Full-Synthetic either, but it's priced nicely, and highly rated. It would work fine in your tractor. If Costco and Amazon sells diesel oil it's likely about the same oil as Super Tech. They are made by Warren Oil Company.
I will point this out. This is not me bad mouthing Kubota, to prop up Deere, but how many people do you know that do not own a Kubota, who actively seek out Kubota branded oils/fluids/coolant/greases/etc? I know people who love their Kubota machines, but no one who just wants to run their oils, and other fluids in machines that are not labeled Kubota. JD on the other hand sells oils/greases/etc that have a large following from people who do not own JD machinery. For example JD Polyurethane grease is very good, and popular. Also JD Cool-Guard II is some of the best spec'd coolant on the market for any vehicle, regardless of brand. I run it in all my vehicles, gas or diesel, truck, or sports car, etc. There are people who switch to JD Cool-Guard II for their racing applications. While I'm sure Kubota oils and fluids are very good, and do their job fine, they are expensive from what I've seen, and they don't have the following that Deere does for these types of products.
What I use
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #48
Good deal, and thanks. I might have to check it out sometime. I'm always shown the blue bottle from Valvoline in Googe searches. Right now I already have bought some synthetic Chevron Delo for my next oil change, as I found it on sale for a good deal last year, and bought it in bulk.
I've started running that new "Valvoline: Restore and Protect" oil in all my gas vehicles. Valvoline is definitely some of my favorite oil, and generally the brand I use for modern ATF fluids like LV or ULV fluids(I prefer Redline D4 for systems that use older, regular ATF fluid) and gear oils, etc.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #49
Look up "motor oil geek" on YouTube. Interesting stuff, has all the answers to your motor oil questions, (including the ones you didn't ask) from a testing and analysis perspective.
The Project Farm channel also reviews a bunch of different oils, but test things like flow stability, evaporation, lubricity, etc.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #50
See Magnuson-Moss warranty act. Can't void a warranty based on the used of non OEM parts.
Yeah, they can't, not that some manufactures won't try but if they say you have to run our brand to keep the warranty in force' then they would have to provide it for you. That's the way it was when I was a boat dealer.
KJ K4525G 45'x25' Double Garage Barn Shed (A60463)
KJ K4525G 45'x25'...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
