OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #1
WVH1977
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
I know this has probably been beat to death on here but does OEM Tractor oil have something magical that Shell Rotella or other standard oils do not have? They are always more expensive and "specially formulated" for their diesel engine.
What would happen if you put John Deere oil in Kubota tractor, etc? Is this a scare tactic to get you to pay more for the OEM oil to your tractor or is there something in the special sauce that makes their oil the best for their tractor?
Are all these diesel tractor engines that much different that you should use only theirs?
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #2
My Kubota in my skid steer calls for 10w30 and claims the use of 15w40 can result in engine damage. Went to the local Kubota dealer to get their special oil, and they tried to sell me Kohler 10w30 which has a diesel rating.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #3
The manual for my Kubota MX6000 calls foe 10W30 below 32 degrees and 15W40 about 32 degrees.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #4
My New Holland specified 10w30 as an oil that could be run year round. Ran T4 Rotella 10w30 for around 10 years, then changed over to T6 Rotella 5w40 as the the T4 was hard to get sometimes. Tractor used both oils without complaint as both weights were listed in manual so I would think any brand diesel oil in weight specified would be ok
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #5
In some cases, the only difference between OEM oil and others is the warranty. With new machinery, it's best to check the fine print to see if it's voided by the used of non OEM under spec products.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #6
How will a dealer know if you used their brand of oil? I mean, I’m not obligated to have them change it for me?
Does Kubota oil taste different than Rotella?
Not sure who makes TYM oil, but I use Rotella T6. If it’s good enough for my sport bikes, it’s good enough for the tractor.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #8
If there is an expensive failure under warranty, the dealer, or tractor manufacturer, can test the oil to see if it meets specs.
I change my own oil but buy OEM product from the dealer and keep the receipts just in case. After the warranty expires, I use other brands that meet spec.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #9
My Mitsubishi manual states the oil/lube numbers only and doesn't mention anything about syntethic.I do know that some engines require a certain rating and additives for the seals.
/ OEM Tractor Oil vs Shell, Valvoline, Amsoil, etc. #10
I have never used OEM engine oil in any machine that I've ever owned. I do use known quality brands, and ensure that they have the correct API classification and viscosity spec that the oem recommends.
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
1667 (A57192)
1667 (A57192)
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
