macdoesit
- Joined
- May 7, 2021
- Messages
- 247
- Tractor
- Mitsubishi MT 2801fd Loader
2004 New Holland, Hist TC30. Bucket on ground wont curl and lift wheels offf the ground. Any ideas, why not??
[emoji[emoji6
[emoji6
]][emoji[emoji6
[emoji6
Ford
[emoji[emoji6
[emoji6
[emoji[emoji6
[emoji6
]] will no doubt that either. I think back then the manufacturer played things safe and set pressures low so people don’t break them.You mean it wont dump and lift the front end? Have you tried giving it a bit of throttle?2004 New Holland, Hist TC30. Bucket on ground wont curl and lift wheels offf the ground. Any ideas, why not??
I have owned it a few years and now the curl wont lift the tractor. When it curls the boom raises. It just started not working a couple days ago.You mean it wont dump and lift the front end? Have you tried giving it a bit of throttle?
The bucket cylinders are good, it will curl but when it does the boom cylinders back off, maybe thee boom cylinders are bleeding off????Sounds like one or both bucket cylinders is leaking internally.
It is not in float mode. It also wont stay in float mode.It sounds like you have the lift spool locked in the float position. Try pulling back on the lift to release it and then try the bucket.
When boom is up it stays there, no bleed off. Very strong lifting. I took the joystick cover off and turned the set screw 3 turns in and no difference, then 3 turns out, then 6 turns in and out and no difference. None of the cylinders leak. Is there an adjustment on the pump.I read your post as bucket not lifting tractor, but loader is limp or floating; got it.
Since it won't stay in float, is it possible the spool has some broken parts in the end cap?
Other question is does the loader hold in position when it is raised off of the ground?
Is valve body and spool the same thing?You dont need to adjust the pump. You have pressure leaking some where in the valve. It could be a seal between the sections of valve body or just a worn spool. Until you take things appart and check for wear and seal condition theres no adjustment to be made.
Yes and no. The valve body is typicaly multi sections of valves that hold the spool valve. The spool valve is the round pieces of steel that you physically move by moving the loader handle.Is valve body and spool the same thing?
I rechecked the lift capacity of the loader and noticed it does not lift as much weight as it used to. A full bucket of firewood was never a problem to lift at any height, now it struggles to get 4' off ground.
With a load in the bucket and lift up several feet it does not bleed off over night.Usually a valve does not fail unless there has been a foreign object passed thru it and the spool was forced within the body, then the lands of the spool or valve would be broken or scored and allow oil to leak from the load. The main failure of a valve is external leaks or lack of control or centering due to loose linkage or loose or broken centering spring. There are no O ring seals inside the valve. The only O rings keep oil from leaking out of the valve.
Does the loader or bucket leak down? especailly when loaded? If so and you want to check the valve change the bucket and main lift cylinder hoses at the valve, remeber the lift and dump functions will be reversed.
With a load in the bucket and frame raised take a screw driver or piece of pipe place it against the barrel of the cylinder and listen for a hiss as oil is bypassing the piston within the cylinder.
A story from my past. When I was working for a dealer a fellow came in and asked for a pump, Once priced he decided that wasn't the problem. Then he asked for a control valve, again the price was an obsticle. So asked him what he was fixing, he stated his loader was leaking down, Suggested he "listen" to the cylinders. Yes a cheap packing kit fixed the dropping problem.
Almost forgot to say remember a pump does NOT make pressure it only moves fluid. The pressure is created by applying a resistence to flow.
A failing pump leaks internally and cannot maintain "as new" flow therefore the volume of oil and depending on wear the ability to produced needed pressure will be problem.
The control valve should also contain a relief valve to keep system pressure to a safe level, usually you can hear it if it bypasses. The control valve may also contain load checks, these are check valves to prevent a load from dropping until system pressure is more than the load.
All loader valves that I am familiar with are made as the attachment explaines.Yes and no. The valve body is typicaly multi sections of valves that hold the spool valve. The spool valve is the round pieces of steel that you physically move by moving the loader handle.
They have lots of seals and or very tight tolerances so any wear can make hydraulics do odd stuff.
Spool valve is good. I switched the hydraulic connections from the boom to bucket and the boom arms still will not stay down when curling the bucket, and the curl is still strong on the boom connections. It must be boom hydraulic cylinders need rebuilt. Seems odd that both cylinders go bad at the same time????I read your post as bucket not lifting tractor, but loader is limp or floating; got it.
