Picked up a used Stihl MS261
   / Picked up a used Stihl MS261 #41
The 462 definitely lighter but I think the 372 smokes it for torque. My so called friend stole my 372.
   / Picked up a used Stihl MS261 #42
I would love to have a new 372 ported by Randy @ Mastermind.
   / Picked up a used Stihl MS261 #43
I have a 500i, but looking for something between that and my 261C
   / Picked up a used Stihl MS261 #44
Ummm, can I kick his ass for you? Stealin saws ain no joke….
   / Picked up a used Stihl MS261 #45
I would use Kevin XS in MI for the 372. He get more out of the saws IMHO.
I ran some of the mm saws. Lot left on the table. I call those somewhat ported.
   / Picked up a used Stihl MS261 #46
A 372 would fit nice between my 261 and 500i……. :unsure:
   / Picked up a used Stihl MS261 #47
MS400 before they stop making those. New model replacing them next year.
or the OE 372 new.
I ran 462 and 500 back to back a friend had with only 20" buried. I liked 462 way better.
   / Picked up a used Stihl MS261 #48
You're in a tough area there really. You have a 50 and an 80cc saw and want a go between. Personally I think the Husky 562XP is one of the finest saws out today. If I were in your shoes, I would have a 16" bar on that 261, have the 562XP wearing a 20" bar, and then use the 500i with probably a 25" bar for the bigger stuff.
   / Picked up a used Stihl MS261 #49
I like the 20” on the 261, but that’s just to help save my back, but I know a 16” would be neat on a 261 or an 18”. my 500i does have a 25” bar which is awesome.
I was all set to start hunting another 261C, but I’m 7/8’s of the way to a 400.
I’m a Stihl guy, so a 400 is tempting…
   / Picked up a used Stihl MS261 #50
PHO weights before mix bar oil b+c. 400 67cc is so light.
   / Picked up a used Stihl MS261 #51
I am a Husky guy for the most part but xyz has just about got me talked into a 400 as well. :LOL:
   / Picked up a used Stihl MS261 #52
I wanted a 400 years back but then found this 670 champ local that needed gone through. Piston etc etc.
So same cc and little more weight with double spikes on if I recall when weighed. Not sure. . But dang great 20" saws.
Tried 24" it did that great too, but balance was off.
   / Picked up a used Stihl MS261 #53
I think what makes a MS261 good is its weight for its power. There are a lot of saws in its class that make just as much power but weigh more. 1 or 2 pounds isn’t a lot of weight but as you get older it makes a difference.
   / Picked up a used Stihl MS261 #54
550 mkII def best cutter stock but comes with that weight penalty. Just a tad over 12lbs PHO now days.
As I got older. I prefer the 50cc to stay in 10lb range or just nipping over 11lbs at worst case.
261 PHO weight. 10lb 14oz
Also why I like the echo 50cc saws. They give up some in the cut. But weigh like 10lbs 8oz.
   / Picked up a used Stihl MS261 #55
Love my 261C, it does bog a little with a 20” chain, but a good operator 😇 can compensate for that.
Honestly, it’s better with 16/18”
   / Picked up a used Stihl MS261 #56
I think I am going to start pursuing a 400 instead of a 261C.
It’s just money. I’ll never have much and I’m not getting any younger.
   / Picked up a used Stihl MS261 #57
This guy does a good comparison. 550 MKII and 261 Gen2 or later.
   / Picked up a used Stihl MS261 #58
Ya MS400 with mag piston could even become sought after down the road too. Maybe even set a extra mag piston back.
Just so you see the new one that is replacement for 400 and 362 and smaller cc then 400 we have now. With use of regular piston again.
   / Picked up a used Stihl MS261 #59
So you think there’s some potential for value enhancement in buying a current 400c with mag piston.
   / Picked up a used Stihl MS261 #60
I think 400 now and 500 will down the road. JMO and what I have seen over the years. Those would be my WAG
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
Enclosed Service Truck (A55788)
Enclosed Service...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
