Cold no start. Frozen fuel?
   / Cold no start. Frozen fuel? #1
Pixguy
Super Star Member
By the lake in NH & FL
2011 MF 2410 TLB
Hi. GC 2410, I haven't used my tractor in a month. Stored outdoors now for the first winter, temps in 20°'s. Battery is on trickle charge and I turned block warmer on an hour ago.
She started up fine but died in 30seconds. Hmm, seems like fuel issue. Look under at fuel filter, full. Shut off fuel line and drop fuel filter and it's full of what seems clean diesel. Replaced and tried to start. She wants to but sputters out before turning over. Fuel is overflowing a full tank when key is on, never saw that before. Took off filter canister and it's empty and left off. Try starting it, hear the pump gurgling but nothing is coming out of lines at the filter.
Frozen? I placed a heater under it and seeing if lines had water and frozen.
Ideas?
Back out to shovel. 😡
   / Cold no start. Frozen fuel? #2
I have heard Diesel has paraffin in it and subject to issues in cold weather. Maybe you could use a hair dryer and heat the fuel lines/tank and get it working.
  • Good Post
Reactions: JWR
   / Cold no start. Frozen fuel? #3
"Fuel is overflowing a full tank"? What does that tell you? It tells me that the fuel pump is pulling fuel out of the filter but supply from the tank is blocked. The filter empties out and nothing is coming from the tank to supply it.
   / Cold no start. Frozen fuel? #4
gelled/frozen.
diesel 911 will help along with the heat you are doing.
fuel come out of a pony tank?
edit:added /frozen to clarify. in the end wording does not matter, fuel line is blocked.
  • Good Post
Reactions: bgr
   / Cold no start. Frozen fuel? #5
Is this pure diesel or bio. At 20 degrees pure diesel shouldn’t gell and since filter wasn’t gelled doubt that is the problem. Like Harry states sounds like an issue with line from tank to filter.
   / Cold no start. Frozen fuel? #6
I’ve had my fuel gel several years ago and that’s what is sounds like. I personally like to add kerosene when it gets cold. When mine gelled it was zero or colder out though.
   / Cold no start. Frozen fuel? #7
Diesel fuel gels when temperatures fall below 10 to 15 degrees Fahrenheit or -12 degrees Celcius. If engine complications occur at temperatures above 10 to 15 degrees Fahrenheit or -12 to -9 degrees Celcius, the issue is likely due to ice rather than gel. However, gelling can occur at temperatures as high as 20 degrees Fahrenheit if the engine runs on low-quality fuel.
Thanks. I'm trying the heater but may put a heat gun on aswell
   / Cold no start. Frozen fuel? #9
serious, diesel 911. not a lot needed.
Ok I was able resolve with heat gun and everything is back to normal. 🤪
It looks like the tractor will spend the next two weeks in my garage til we head south. Now I have to break the news to my pickup. 🤣
Thanks to all.
2005 John Deere 7420 (A60462)
2005 John Deere...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
