Do you think I will be able to lift this? Kubota M7060
/ Do you think I will be able to lift this? Kubota M7060 #1
Jrasband
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
We are wanting to buy a hoop barn and this is the size that I am looking at. It seems to be the biggest that I will be able to fit on the pad I created, it also seems to be the biggest the M7060 will be able to pick up. We are looking at the 36x48, and it weighs 2,500 lbs. Do you think I will have any trouble lifting this off the delivery truck? I have light duty pallet fork frame I could use to save on weight if needed.
/ Do you think I will be able to lift this? Kubota M7060 #2
It appears your rated lifting capacity is 2535 lbs to full height at the pins. Capacity decreases as the load moves forward of the pins, but also increases with reduced heights.
I could do some really fuzzy math with percentages, but it would still end up being a guess. Depending on how the load is palletized, I suspect you could lift it an inch or two to get it off the truck, then keep it close to the ground to its final destination.
Worst case you could break it apart on the truck, but the driver may not like that too much.
Just to throw out MY numbers (different tractor and loader) to get an idea of lift height and distance from pins:
Loader lift capacity at pins 1720 lbs (full height)
Loader lift capacity 500mm (20”) forward 1292 lbs (full height)
Loader lift capacity at pins 2202 lbs (1.5m height)
Loader lift capacity 500mm (20”) forward 1766 lbs (1.5m height)
/ Do you think I will be able to lift this? Kubota M7060 #3
I have my doubts. A lot of that weight will be far from the base of the forks and that leverage makes a difference. I lift pallets of wood pellets off my trailer every year. Each pallet weight just over 2000 lb. I have to have my rotary mower on the 3 point hitch or trying to lift that 2000 lb just lifts the back of the tractor. And I have to air up the front tires to 30 psi! Does your M7060 have cast iron rims and liquid ballast in the tires?
  • Good Post
Reactions: JJT
I do have cast wheels and liquid ballast. I am not worried about the back end coming up on me I will be on level ground and I have not had problems with the back end lifting much.
The pallet it will be on seems to be standard depth, but is 10' wide or so. I will have to confirm this.
Yeah I am thinking I will be able to manage it.
In the past I have managed to get stuff off of trucks by dragging with the forks off the truck and than quickly lowering to the ground once it comes off the truck lol. I do not think I want to do this with a $10,000 pallet though.
I was thinking of having a back up option of using some kind of come-a-long(or somehow using the tractor) to drag it off the truck into the back of my light duty dump truck.
/ Do you think I will be able to lift this? Kubota M7060 #7
How deep is the pallet? If it’s like a standard pallet depth it would probably be fine. If it’s a deep pallet like as wide as the trailer deck I seriously doubt it lifts it.
/ Do you think I will be able to lift this? Kubota M7060 #8
If the frame members get bent in the processing of unloading, that may make final assembly more difficult.
That's why I am not going to drag it off the truck to the ground with the tractor loader if it can't pick it up. I think i could carefully drag it though into my truck somehow, the dump bed is much higher and lines up close to the trailer height.
/ Do you think I will be able to lift this? Kubota M7060 #10
Do any of your neighbors have a tractor loader? Often with heavy loads, we use two forklifts. Lift the pallet up high enough and let the truck drive out from underneath it and lower it to the ground. Then you can break it apart as you build the building.
Yeah there are couple bigger tractors around, that is a option.
The pallet will have to get unloaded on the one lane gravel road in front of my property and carried up to the site from there.
/ Do you think I will be able to lift this? Kubota M7060 #12
Are you sure it all gets shipped on only one pallet ?
If that’s the case I would be asking them to use at least two pallets to make it much easier safer for you to handle with your tractor.
Yeah it comes on one pallet and no I don't want to even ask that because I don't want to pay the freight for another pallet. I can ask a neighbor to lift if need be or prob get it loaded at whatever local dock it will be arriving at before delivery. There is not much risk here as far as it being unsafe... I am not trying to drive the pallet across any side slope.
/ Do you think I will be able to lift this? Kubota M7060 #14
Sounds like you have options. Good luck with your new building!
Be sure to post followups!
/ Do you think I will be able to lift this? Kubota M7060 #15
As a former owner of 3 Kubota farm tractors, I think theres a bigger issue you might be overlooking.
I put new bearings in the front ends of 3 or 4 of them from lifting at/above the load limit.
Maybe once you’ll be OK, but repeated lifting on the bevel axle front ends causes seal/bearing failure.
The bevel front axle is a nice feature for ground clearance, but its a weakness if you overload the loader
/ Do you think I will be able to lift this? Kubota M7060 #16
If the pallet is 10' wide, it will likely be loaded on the truck end wise. Unless it's a flat bed truck, that means you will have to lift it from the end. With that much weight forward, I doubt you will be able to lift it with your forks.
I have done what others have suggested. I pulled the pallet off the truck onto the forks and quickly lowered it to the ground. I was then able to pick it up from the side. Make sure you have enough rear ballast if you try this!
On one occasion, I had to break open the pallet and carry it it two trips.
/ Do you think I will be able to lift this? Kubota M7060 #17
I've had two M7040 Kubotas and often lifted 2,000 lb pallets. They were a handful unless on a perfectly flat surface. I have two weights on each side and heavy radial rears with cast wheel centers.
Even so, I don't think I could lift 2500 lbs. If I could somehow lift it I would be afraid I would tip or drop it. If you do try it, just have your backup tractor on site and warmed up just in case. Good luck.
/ Do you think I will be able to lift this? Kubota M7060 #18
That's 2,947# plus weight of skid and securing method. I'd count on having to lift 3,200#. If the load is not centered on the pallet, you have another issue. It could be easy to overturn the tractor with the bottom of the heavy load 50" off the ground.
Skid is 10' wide you said, that means you'll have to lift the skid then the truck driver pull out from under the skid unless your unload area is large. (You should use rear ballast)
/ Do you think I will be able to lift this? Kubota M7060 #19
Any way you can get in touch with the company that is going to deliver your material with a lift gate, this would solve your problem.
/ Do you think I will be able to lift this? Kubota M7060 #20
I recently received a crate of solar panels that weighed 2298 lbs. my MF2705E loader with forks is rated at 2300 lbs. I can report that I was able to raise it only a few inches off the truck bed so that the truck could move forward and the load lowered. It’s imperative that you have substantial weight on your 3 point hitch for this to work otherwise the tractor could easily tip forward (I had a heavy Gannon box blade).
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
2012 International (A59230)
2012 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Chevrolet Express 2500 Cargo Van (A61568)
2017 Chevrolet...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
