3-Point Hitch Ugh, she is doing it again. (CK2610)
/ Ugh, she is doing it again. (CK2610) #1
tacticalturnip
Super Member
NW Atlantic
Kioti CK2610HST
So I decided to tear up and smooth out the driveway before winter. I got the tear up part about done and she again doesn't want to drop the 3 point.
Turned the dial for drop-rate back and forth a bit to see if that had stove up a bit, it didn't help any. This doesn't seem a common problem, so I'm irritated.
I'll give the dealer a call tomorrow.
/ Ugh, she is doing it again. (CK2610) #2
If you have a latching (detent)remote lever, make sure it isnt locked in forward or reverse. If mine gets accidentally locked into detent, the 3 point locks up.
The 2nd thing I checked. 🤬🤣
The dealer ought to call me back, but hasn't yet. In the meantime I used the loader to backdrag the driveway, and as soon as that was done I took a photo.
I got the driveway about back to what it was before I started, and suddenly found my 3 point worked again.
So I started smoothing it out with the box blade. It worked nicely until it didn't; the control ceased working.
They're picking her up tomorrow.
/ Ugh, she is doing it again. (CK2610) #7
Did you get your problem resolved if so what was it?
She still is at the dealer, I'm trying to be patient but I'm not thrilled. I know they're understaffed, and I want to be understanding.
Waiting on a part. Literally the biggest potential issue with Korean tractors.
/ Ugh, she is doing it again. (CK2610) #11
Waiting on parts happens with all brands. In the 1970's a friend bought a new JD 4020 (I think) He began plowing in April preparing for spring planting.
The generator stopped working so he removed it and took it to the selling dealer.
The parts man said a new one would have to be ordered from France.
Well, my friend threw a fit, the owner heard the commotion and came to see what was happening. When the owner realized the facts he told the parts man; " we have another new tractor on the sales lot, go remove the generator and give it to Jerry. He spend a lot of money on his new tractor, if anyone has to wait on parts it will be us. Spring planting cannot wait".
/ Ugh, she is doing it again. (CK2610) #12
I have a new used once pressure washer in the shop right now under warranty. Won't produce pressure. No replacement parts for the pump available, and the replacement pump is backordered until March.
/ Ugh, she is doing it again. (CK2610) #13
Did they give you any ideas on what part is causing the issue? Wouldn't surprise me if it was a simple case of taking the 3 pt valve apart or the flow control valve apart, to inspected and clean. Then put back together. I wondering if a bit of trash is holding a valve close when it should open.
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
HONDA Plate Compactor (A64557)
HONDA Plate...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
3268 (A63117)
3268 (A63117)
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
