Ball hitch adapter
/ Ball hitch adapter #1
Aggie66
Rockdale TX
MX 5400
I have a Kubota MX5400. We have three 16ft. trailers on our place that we move around time to time. I want to use the tractor to do this instead of using my pickup. Do clamp on bucket ball hitches work or an A frame three point work better or suggestions on something that works for you. I know drilling a hole in forks works but we typically don’t have the forks on unless needing them. Mostly bucket is on. Any suggestions appreciated.
/ Ball hitch adapter #2
I have a ball attached to my draw bar & use that to move my trailers around
/ Ball hitch adapter #3
I drilled a hole in the lip of my box blade and put a ball on it. Used this setup for years, then broke down and bought a 3 point hitch receiver off amazon to allow for more maneuverability. Also used the draw bar with a ball, but you have to get off and manually crank the handle on the trailer jack and is less maneuverable. 3 point hitch receiver is by far the easiest.
/ Ball hitch adapter #4
I use a three point "trailer mover" I picked up at TSC. Has a 2" hitch receiver low for bumper pull heights or the upper ball for goosenecks. I use it for a 15K 20 footer as well as a boat trailer (with boat on it). You could probably get away with either a 3 point or bucket attached if the trailers are empty, any real tongue weight, & the 3 point is probably the better choice. Not sure how solid the clamps are for clamp ons, or your bucket height vs trailer hitch, but I've seen pics of folks attaching a ball on top of their bucket (usually a welded strength strip and thru bolted).
/ Ball hitch adapter #5
I have a three point receiver set up for my quick hitch. That's very convenient. I also have a quick hitch that I can mount on the loader arms in place of the bucket. Hitch on the rear is very quick. With it on the front, it's great for backing a trailer into a tight spot, but takes a little longer to install.
/ Ball hitch adapter #6
When I built my trailer mover I put it on the 3 point, no need to get off the tractor. Just back up to the trailer raise the 3 point and go, no need to raise or lower the jack. I go slow and seldom ever fasten the trailer hitch since I usually don't have to move them very far
/ Ball hitch adapter #7
I also built a 3-point trailer mover. Used the bumper mount 2" hitch box from HF. Way quicker than having to get off to crank jack! Able to spin a trailer in pretty tight spots.
Also made a quick pallet mover that goes into 2" box. It's similar to a quick hitch, but heavier build.
Haven't needed to have an upper ball for gooseneck, but I can add a plate if/when needed. Might need to think about how to add a cup to be able to move small 5th wheel trailers.
/ Ball hitch adapter #8
Some like this should work just fine:
Sponsored Ad - YZONA 3 Point Trailer Hitch with 2 Receiver for Category 1, 3 Pt Tractor, Heavy Duty Quick Hitch Drawbar A...
AMAZON
3 Point Trailer Hitch with 2" Receiver for Category 1, 3 Pt Tractor, Heavy Duty Quick Hitch Drawbar Adapter for John Deere, Kubota, Kioti, Yanmar, Cat, NorTrac, BX, LM25H, WLM Tractor, Black
$49.99
willy
/ Ball hitch adapter #9
Have a receiver on the bucket and a receiver on the brush guard. Mounted a ball on the RFM so I can move the utility trailer and generator for mowing. Had a ball on the bucket of the last tractor.
/ Ball hitch adapter #10
Avoid "clamp on".... I had a clamp on hitch on FEl and as I was moving trailer it came free and all I could do is watch as trailer ran into nephews Toyota.....
What I am saying is only use solid mechanical connection (bolts and nuts or lock pins)....
My personal choice now is trailer ball on 3PH ( draw bar or "A" frame)....
/ Ball hitch adapter #11
I cut and welded in a receiver tube into my quick hitch
/ Ball hitch adapter #12
I have two different clamp on types. Yes you must make sure they are very tight when clamped. This type works for me because I have almost level ground, trailers are usually empty. Have big pontoon, 20ft car hauler, 16fy box trailer, 5x8 utility. This type is conveinent for me. I have an L2500 with a loader and my blade is on most of the time. As mentioned makes backing the trailer into a tight space pretty easy since your looking straight at it. I would not be able to move the car hauler or the box trailer if they are loaded full. But when they have heavy loads, they are probably already hooked to my truck or dropped where the truck is going to hook up anyways. If i was pulling a trailer a long way through the woods, it would be hooked to the rear of the tractor or truck.
This system works for me.
/ Ball hitch adapter #13
I use a loader mounted quick hitch combined with a three-point trailer hitch as shown in this post:
/ Ball hitch adapter #14
One other thing to keep in mind is the leverage on your front end & loader arms. Again, empty trailers & flat terrain are probably ok front mounted, but the further out front your hitch ball is & the bumpier your ground, the more weight you are transferring to the front axle & shock loads to loader arms. Convenient? yes. Potentially costly repair bill? also yes.
/ Ball hitch adapter #16
My first set of pallet forks was cheap Chinese junk. It didn’t take me any time at all to trash one fork, but the other fork has a hole for a ball. If I’m moving a trailer for a short distance, or need more maneuverability, I use the fork, otherwise I have a ball on the drawbar.
/ Ball hitch adapter #17
Here's something interesting:
/ Ball hitch adapter #18
I use a 3 point trailer hitch.
It's never a good idea to use a loader to move trailers.
/ Ball hitch adapter #19
As far as I'm concerned moving a trailer with a loader mounted hitch is of no concern. The loads are no more then you get digging into and lifting a bucket full of gravel. It is certainly no harder then using a push blade on an ssqa, especially an angled snow blade. Or turning with a bucket loader on the ground.
/ Ball hitch adapter #20
I have a ball on the draw bar.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X128824 (A65563)
2009 Ford Crown...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
