BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 2,753
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
Thanks everyone for the condolences, I appreciate it.
A while back, I came across another term that is used to describe what we, in this area call "doing donuts." I think in Minnesota they call it "whipping ****ties." Someone needs to check out what may be in the water up there.On the snow note... I used to love my 70 Nova in the snow. Donut city!![]()
A friend has a 454 big block Suburban he ordered new, '95, 60kM. For sale, always garaged. S. Va. though.Well, I have it almost done. Worked for a little over three hours this afternoon, and got everything done except for installing the shifter and trim plate, and filling it with coolant.
I messed up and didn't install two bolts in the backs of the heads that hold the ignition wire loom braces, and due to the limited space between the firewall and the heads, they are real buggers to get in. The left one wasn't too bad, but the right one was, I ended up having to take the rocker cover back off to be able to get it in. Then, when I installed the wire looms, getting them tight was no fun either. Again, the left one wasn't terrible, I ended up being able to get a 3/8" ratcheting wrench on it to tighten it, but the right one was blocked by a couple of wire harnesses and a heater box stud. I ended up getting it from underneath, with a long 3/8" box end wrench, 1/12th of a turn at a time.
I got the clutch linkage hooked up, the bolt on the outboard end of the Z-bar is a real treat too, zero room to get at it with a wrench or ratchet. I ended up using a short box end wrench to get it tight.
I tied all the wiring up and out of the way of any moving and hot parts, got the exhaust connected up and put the driveshaft in.
Of course, the distributor fought me too, it fits tighter in this block, not sure why, possibly the intake manifold is shifted one way or the other a slight bit, don't know. But after rocking the crank back and forth and pushing down on it, the distributor finally dropped into place.
So, after all that, it was tired, closed up the shop and will finish it up tomorrow, maybe. I found a really nice Suburban at a dealer 100 miles from here, that I may have to go take a look at, if the deal is good enough. We'll see.
So I'm getting close....
View attachment 1899299View attachment 1899300
