New 2025 Ram 1500 with hurricane engine.
   / New 2025 Ram 1500 with hurricane engine. #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Any opinions on the new 2025 Ram 1500 with the standard hurricane inline 6cly.with twin turbos?I currently have a 2022 Ram 1500 with the 5.7 hemi.Thinking about trading up to a 2025.
   / New 2025 Ram 1500 with hurricane engine. #2
It looks like even the standard Hurricane engine has more torque and hp than the 5.7L Hemi, as configured for the Ram 1500. Not by enough to make it worth swapping trucks, IMO, but at least it's not worse. It would be interesting to lay their dyno curves side-by-side, and see if this new inline-6 is just peaked over a smaller RPM range to publish better numbers, or if it really holds its weight over the full RPM range.
The Hurricane H/O looks like a beast, but again, I'd like to see the HP and torque vs. RPM curves laid out against something I know.
   / New 2025 Ram 1500 with hurricane engine. #3
...Thinking about trading up to a 2025.
Why? Is the "old" truck falling apart? Rusting away?? or Money burning a hole in your pockets?
I still want at least 6 more years out of my 2009 Toyota Tacoma, 185,000 miles and I've disliked the interior of the truck since forever and it gets crappy gas mileage, 16.5 mpg.
You can't take the money with ya' so why not spend it?
Trucks are so over priced, I just can't waste it like that... That's my 2 cents dollars!
   / New 2025 Ram 1500 with hurricane engine. #5
The HO version requires 91 octane.
A drawback to consider
   / New 2025 Ram 1500 with hurricane engine. #6
Not a surprise. With compression (or boost), always comes a requirement for higher octane, to avoid pre-detonation.
But even the old 5.7L "recommends" mid-grade. I don't remember the cutoff, whether it's 89 or 91, as most of our stations just have one or the other, so I always just select the middle grade. But either way, Ram doesn't recommend regular 87 octane in the 5.7L. The difference is that the 5.7L will still run fine on 87 octane, but the manual states the ECM will adjust around it, and performance will not be "optimal". This likely means adjusting timing according to knock sensor, but not my area of expertise to really know.
Most of our stations here are 87 regular, 93 premium, and then one in-between, whether that be 89 or 91. A few stations (Wawa & Sunoco) have 4 grades, but you end up paying across the board for that, as inventorying 4 costs them more than inventorying 3 grades. So if running the HO, you might end up buying 93 Premium, at stations only stocking 87/89/93.
edit: According to Google, Ram 5.7L "requires" 89 octane. I'm pretty sure the paper manual sitting in my glove box says 'recommends". Either way, not buying regular 87, for either.
   / New 2025 Ram 1500 with hurricane engine. #7
6 cylinder engines in general make peak torque at lower RPM and usually have a flatter more useable torque curve.
My BMW X5 has a 4L twin turbo in line 6 that pulls really hard.
   / New 2025 Ram 1500 with hurricane engine. #9
Turbos are pretty reliable, but the twin set ups make me pause a bit. My Challenger MT655E has twin turbos and an 8.4L AGCO POWER in line 6. Not cheap to replace those turbos and one is beginning to slobber a little oil. :(
I bet that ram is fun to drive when both are fully engaged. Kind of reminds me of a 70’s truck with a 4 barrel carb kicking in.
I can’t wait for the 2025 Ram 4500/5500. We are supposed to get a ZF-8 “super” automatic transmission and some other upgrades.
   / New 2025 Ram 1500 with hurricane engine. #10
FWIW: at one point, Sunoco was doing at the pump blending, in their "Blend-o-matic" pumps, so no need to have inventories of all grades. I have no idea if that is still the case. E.g.
Sunoco has a long history in fuel blending, especially for high performance fuels, e.g. racing.
All the best,
Peter
   / New 2025 Ram 1500 with hurricane engine. #11
We have Sunocos all over the place in my area. Only about 30 miles from Paulsboro, NJ refinery.
I used to like the “Ultra 94” with no ethanol.
That’s gone and replaced with “Ultra 93” and pretty sure it has ethanol.
   / New 2025 Ram 1500 with hurricane engine. #12
Mines a '19 Ram 1500 with the hemi, I'm going to stick with it. Twin turbos gives you twin cost when they go down, more moving parts, my 2 cents worth. When they start getting that much HP and torque out of a 6 cylinder, you're working it. I'd sooner have an 8 that's lazing around rather than a 6 that's working hard most of the time. Just my opinion.
What makes it 'super"?
Mine in my Ram is a ZF8 (not super) and it's described as a great transmission, BWM, Audi, Benz and a bunch of others use it.. I'm not overly impressed with it, seems to lug a lot, the lock up torque converter is rough or hiccup is a better description when it disengages when coming from a coast to a mild acceleration. It could very well be the Ram software and not a fault of the transmission I suppose. I've been back to the dealer a couple times right after I got it and I get the 'It's normal, go away" .
I'm considering changing the fluid with 85KMS on it now and going with Valvoline MaxLife which is approved for the ZF8 and is a lot better priced that $30 a liter for the ZF fluid.
   / New 2025 Ram 1500 with hurricane engine. #13
Careful there. There are a wide range of ZF8's out there, and they are far from equal. I have a ZF 8HP-70 in my Ram 5.7L Hemi, but the 8HP-90 in my SRT 392. Both 8-speed transmissions made by ZF, but as alike as comparing an F150 to an F350.
   / New 2025 Ram 1500 with hurricane engine. #14
I bought my Taco Wagon (2018 Ram HD 2500 Power Wagon) in 2018 because that is what I wanted. That new Ram looks great but just not what I want.
NOW - if they put a diesel in a future Power Wagon - I might consider an upgrade.
   / New 2025 Ram 1500 with hurricane engine. #15
As is mine. Does yours have the hiccup when mildly accelerating from slow/moderate speed?
   / New 2025 Ram 1500 with hurricane engine. #16
Yes, mine has a hiccup. As to precisely when it happens or what causes it, I haven't nailed that down, yet. It doesn't happen often, maybe a half dozen to a dozen times in the 7 years I've owned it, but it is weird.
If you say "mild" acceleration is when it happens, that might explain why I've rarely seen it. :ROFLMAO: I don't drive that truck particularly fast, in fact I think most others drive too fast when not in a car designed for handling, but I'm a bit of a lead foot off the line in any vehicle.
We also have a Durango R/T, which I think also has an 8HP-70. It gives you this weird kick in the ass when decelerating to a stop in Sport mode. Very unpleasant, makes you feel like the car is trying to rear-end the vehicle stopped in front of you. But it only does that in Sport mode, it's well-behaved in standard mode. It's like they're trying to do nicely-programmed downshifts, but didn't get the timing/accelerator compensation right.
The 8HP-90 has neither of these behaviors, it is a truly sublime transmission, especially in sport or track modes.
   / New 2025 Ram 1500 with hurricane engine. #17
Most newer stations only have 87 and 93 underground tanks. The E85 and diesel would be in separate tanks as well. The in between grades, including E15, are blended at the dispenser. These are Gilbarco dispenser specs.
Old truck is fine just want to upgrade.Thanks.
   / New 2025 Ram 1500 with hurricane engine. #20
That's cool, and probably explains why I see so many new grades and variants popping up, at Wawa in particular.
When I worked at a gas station in HS, we had five underground tanks, for "Regular", "Plus" and "Premium", as well as diesel and kero. Eliminating the Plus product, and achieving it by mixing regular and premium, would free up an existing tank for another product (eg. bio diesel), in addition permitting both 89 and 91, instead of either/or.
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
5' MOWER (A52706)
5' MOWER (A52706)
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
