Telescoping 3 point stabilizers for LS MT122
/ Telescoping 3 point stabilizers for LS MT122 #1
BrucFitz
Woodbury, CT
Ford 2000
Does anyone know where you can get telescoping stabilizers to replace the turnbuckle set up. Turnbuckles are a royal pain to use. Thanks
/ Telescoping 3 point stabilizers for LS MT122 #2
Messicks New Holland stabilizers are the same as LS - I bought 2 1 for a back up and 1 to replace one I broke. These are for my MT3 tractor....
here's the link:
Thanks for your help. Unfortunately they couldn’t help. Evidently when you get to LS 30hp plus machines they can determine compatibility but, not on sub compact models. It seems there are none available. The turnbuckle set up on the MT122 sucks. The tractor side connection is welded to frame…cheaply done.
/ Telescoping 3 point stabilizers for LS MT122 #4
I've built them for the New Holland 25s, which is the same set up. However, they aren't a bolt on set. The pivot tubes need to be changed (which I supply), the lift arm ears need to be cut off, and a hole needs to be drilled in each lift arm for relocation brackets (which I also supply). The factory set up, the length from the pivot tubes mounts to the ear mounts, is too short for telescoping stabilizers.
You can PM me, if you'd like an estimate.
Could you provide me a quote? I’m not a techie. Not sure how to pm you.
/ Telescoping 3 point stabilizers for LS MT122 #6
Mouse over his username "hodge" then click on "Send Private Message".
EZ Trail 3400 (A63118)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 MACK GRANITE POLE TRUCK (A63569)
2009 MACK GRANITE...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
