Storing Tractor
/ Storing Tractor #1
Mucksiegooma
John Deere X-350
I store my John Deere X-350 in an unheated, non-electricfied out building. I do not want to remove the battery from the tractor, I disconnected the
positive battery cable. Did I do the correct cable or should I have disconnected the ground cable? Does it make a difference?
Please advise.
Thank you!
/ Storing Tractor #2
Electrically it doesn't make a difference, but the safest thing to do is disconnect the negative cable. When you mess with the positive cable with the negative connected, any tool contact with the tractor case is a direct short.
/ Storing Tractor #3
Please advise.
Thank you!
Why disconnect the battery?
  • Good Post
Reactions: JJT
/ Storing Tractor #4
I change the oil, sharpen/replace the blades, grease every fitting and clean the deck of my mower before storing it for the winter. 40 years and I've never disconnected the battery for the winter.
/ Storing Tractor #5
Take away the minus cable first. Upon reinstalling add the plus cable first.
Might as well remove the battery, you’re halfway there. Store it in the basement on a 1 amp maintainer. Prevents freezing, draining the charge and adds a few years life…🥴
/ Storing Tractor #6
Do you leave in cold weather region,if not I wouldn't disconnect.
/ Storing Tractor #7
Because if there is ANY parasitic draw, it will kill the battery. I have NEGATIVE disconnects on m y tractors and In use them all the time. A flooded cell battery not hooked up and fully charged looses about 5% of it's total charge per month.
/ Storing Tractor #9
Please advise.
Thank you!
Mucksiegooma
Welcome to TBN
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
JOHN DEERE 400 ROTARY HOE (A63745)
JOHN DEERE 400...
2021 TAKEUCHI TL12V2 SKID STEER (A63290)
2021 TAKEUCHI...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
378909 (A61166)
378909 (A61166)
2008 New Holland T2420 (A62177)
2008 New Holland...
