Storing Tractor
/ Storing Tractor #1
Mucksiegooma
John Deere X-350
I store my John Deere X-350 in an unheated, non-electricfied out building. I do not want to remove the battery from the tractor, I disconnected the
positive battery cable. Did I do the correct cable or should I have disconnected the ground cable? Does it make a difference?
Please advise.
Thank you!
/ Storing Tractor #2
Electrically it doesn't make a difference, but the safest thing to do is disconnect the negative cable. When you mess with the positive cable with the negative connected, any tool contact with the tractor case is a direct short.
/ Storing Tractor #3
Please advise.
Thank you!
Why disconnect the battery?
  • Good Post
Reactions: JJT
/ Storing Tractor #4
I change the oil, sharpen/replace the blades, grease every fitting and clean the deck of my mower before storing it for the winter. 40 years and I've never disconnected the battery for the winter.
/ Storing Tractor #5
Take away the minus cable first. Upon reinstalling add the plus cable first.
Might as well remove the battery, you’re halfway there. Store it in the basement on a 1 amp maintainer. Prevents freezing, draining the charge and adds a few years life…🥴
/ Storing Tractor #6
Do you leave in cold weather region,if not I wouldn't disconnect.
/ Storing Tractor #7
Because if there is ANY parasitic draw, it will kill the battery. I have NEGATIVE disconnects on m y tractors and In use them all the time. A flooded cell battery not hooked up and fully charged looses about 5% of it's total charge per month.
/ Storing Tractor #9
Please advise.
Thank you!
Mucksiegooma
Welcome to TBN
2021 CATERPILLAR 299D3 SKID STEER (A62129)
2021 CATERPILLAR...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
(2) UNUSED 7.5L-15 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 7.5L-15...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
