3 Point Hitch slow and unintended dropping
   / 3 Point Hitch slow and unintended dropping
My kioti often drops slowly when I trav erse down the rod, and it's bumpy. Since the first time when I am driving any distance I always lift up on the draft control lever. That has always stopped it for me. ??
Mine never did before I installed my second set of valves. Did you by any chance have the dealer install a second set of valves before you took delivery ?
   / 3 Point Hitch slow and unintended dropping #12
The ancient Kubota B7200 that I use as a snow blower has a CHAIN that is meant to be used to tie up the lift during transport.
Might be a good idea ,...even today, In these modern times and expectations.
   / 3 Point Hitch slow and unintended dropping #13
OR - just close down the 3-point speed valve; located under the seat when you want to "go" with heavy items on the 3-point. The leakage is internal, it's slow - your aren't loosing any hydraulic fluid.
   / 3 Point Hitch slow and unintended dropping #14
I bought the OEM kit from Kioti which basically allows to install an extra double acting valve assembly. My tractor came with one set of valves in the back. The installation involved taking off the valve cover from the OEM valve assembly, install longer bolts, and add a second double acting assembly (#1 in the schematic below) next to it. It is positioned just under the driver's seat, to the right. I attached the installation instructions that came with the manual as a pdf file. Slide 1 provides a quick overview of the system. Here's a screenshot, further details attached :
I can't see how just installing the remotes would affect the 3 pt hitch. It's pretty much a "fool" proof system, unless some trash got in and got stuck in the 3 pt valve (MLS valve) and it's causing the issues.
I can see the end round cap, could go two ways. Is it installed the right way? I think if installed the wrong way, you would have other issues.
   / 3 Point Hitch slow and unintended dropping #15
Mr. PTSG is a great source of knowledge...he's helped guide me out of the wilderness in the past!
You sound like you're hands-on. Wondering if there is an easy way to return it to the original configuration removing the added valve. Then test if the symptoms clear?
Are you able to dissamble the valve spool to observe if there is anything foreign or a nick on the internal seals?
Indeed, I have to disassemble some stuff to get to the bottom of this. To be transparent, I've had Porsches and Ducatis with 'engine out' procedures in my shop, but I'm new to hydraulics. This is a wonderful community to learn a new skill set.
   / 3 Point Hitch slow and unintended dropping #17
I had a bucket which bled down and fixed it by changing the transmission oil. Had water in the oil.
   / 3 Point Hitch slow and unintended dropping #18
This happens occasionally on my 1532 MF. The lever that controls the 3pt position pivots on a shaft and is sandwiched between 2 fiber friction washers. The shaft is threaded and has a pair of nuts locked together These do wear and need to be readjusted to hold the lever in the desired position.
   / 3 Point Hitch slow and unintended dropping #19
If the hydraulics didn't drop before you fitted the additional slice(extra outlet) the problem could be in the additional slice. Some additional slices have a grub screw in them that either has to be either removed or shifted to another hole, this controls the oil flow, power beyond or return to tank.
   / 3 Point Hitch slow and unintended dropping #20
Need some help getting to the root cause of my 3 point hitch dropping slowly and unintended.
Tractor : Kioti NS6010 Hydrostatic transmission, 60HP
Symptoms : 3 point hitch drops slowly when it is loaded with the weight of e.g. my flail mower. Over about a quarter mile of riding it will go from top position all way to dragging. This never happened during my first year of ownership.
Additional important data points :
  • As said, it happens slowly. When I engage the locking knob on the hitch control lever (when set in the highest position), I can prevent the hitch from dropping at all. This leads me to assume that not a lot of force/leakage is involved.
  • I installed a third function up-front. No leaks and no such spontaneous dropping on the FL.
  • I also installed a set of extra valves in the back. Upon activating them the first time I blew a small rubber gasket where the additional valve unit was clamped to the OEM one. This resulted in hydraulic fluid spraying all over the place. Most probably the rubber gasket between the 2 valve units got pinched, causing a leak. Anyhow, I was able to fix the issue by installing a new gasket. No more leaks. Having said that, the dropping started somewhere around the time-frame where i added the extra set of valves.
  • Both primary and secondary valve set in the back work fine, as tested with a flail mower which needs both sets. No leaks.
  • Hydraulic fluid is at the appropriate level
I investigated these symptoms through an on-line search and in most cases there is some kind of a hydraulic leak involved. To the best of my knowledge, I have zero leaks. This has been confirmed both through visual inspection and checking the level of my hydraulic tank.
Can anybody throw me a bone ?
Did you ever find a solution to this? I have the same issue.
2017 Liebherr L566 X Power Articulating Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel (A59076)
2017 Liebherr L566...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56436)
J and L Cargo...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
