Boring Ford engine question
/ Boring Ford engine question #1
City Farmer
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hey guys,
I have a couple Ford 445 blocks around the farm and three new 4.400” standard pistons from a 4500 on the shelf.
The bore to stroke on a 445 is 4.200” x 4.400”
Can I bore this block to accept 4.400” pistons without sleeving it? I’m doing the machining myself and not sure if I have to order sleeves before I start this winter project.
Thanks,
Andy
/ Boring Ford engine question #2
Are you saying you want to install 3 larger pistons in an engine? If so, I'd say_yes order new cyl liners the right size.
Boring a sleeve .200" oversize would be a disaster waiting to happen. IMO
/ Boring Ford engine question #3
Some info on the Ford 445 blo;ck
The maximum bore diameter for a Ford 445 block is 4.080 inches. The 445 stroker is a street-brawler engine based on a 390 block that has been machined to this size.
willy
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
Sakai SW354 (A60462)
