Boomer hydraulics
/ Boomer hydraulics #1
1chriswhittle
Wigan
mf35 NH 3050
Does anyone know what size control valve I need for a loader on a NH boomer 3050.Thanks for looking,any help would be great
/ Boomer hydraulics #2
Any 10 GPM valve should work for you. Dozens of them out there to choose from.
/ Boomer hydraulics
Thank you there seems to be quite a few and all at different prices, Thanks for the prompt reply
/ Boomer hydraulics #4
Yes indeed. No shortage of them. This is one I have used many times. I've had good luck with them. There are many others as you have seen, at many prices. This too is available from other suppliers at varying prices. It's features check all the boxes I look for in a typical small tractor loader valve. Whatever you decide on, be sure to order the corresponding power beyond sleeve on that same invoice.
/ Boomer hydraulics
Thank you for taking the time to reply but I'm in the UK so I'll try and find one a bit closer to home
/ Boomer hydraulics #6
Check with FlowFit. I'm sure they will help you out if you contact them.
I'm in Portugal and used to buy from them fairly frequently before Brexit came in. I've always had good experiences and great prices with them.
/ Boomer hydraulics #7
Not suggesting the seller, merely pointing out the product and it's features. It has all the features I look for when installing a loader valve.
Not that it matters, but I failed to see your location listed anywhere.
Quick Attach Snow Push (A66408)
Quick Attach Snow...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Marcrest BSP449 (A64127)
Marcrest BSP449...
12 Ton Hydraulic Jack (A64127)
12 Ton Hydraulic...
