2008 CK30 won't start
/ 2008 CK30 won't start #1
DOCatRU
Wallingford, VT
Kioti CK 30 (2008, gear drive, 415 hours)
Hi folks:
My 2008 CK 30 is having some starting issues. I replaced the ignition switch, but no joy.
I can start the tractor by turning the key, locking the clutch pedal and then jumping the two poles on the start motor with a screwdriver.
I swapped the glow plug relay for the ignition relay and it still didn't work. :-(
Any suggestions to solve this issue are greatly appreciated.
DOC
/ 2008 CK30 won't start #2
That is a good test. It eliminates the fuel solenoid as an issue.
So, you are experiencing the starter motor lockout safety, most likely. I do not know exactly which safety switches you have, but I suspect you have one for the PTO and neutral, as well as the clutch. Mine is older and an HST. I have disabled my only safety switch (clutch).
Hedge Posts (A65640)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2008 Mercury Mariner (A62679)
2008 Mercury...
