Largest tractor with a belly mower.
   / Largest tractor with a belly mower.
I had an old flail mower once. Never again! Thing was broken more than it ever mowed
   / Largest tractor with a belly mower. #12
Kioti builds the CK2610 in Bobcat white as a CT2025 and it's available with a belly mower. That's one of the largest machines I can think of with a mid-mount mower. Oddly enough, while the Kioti CK series is available with a mid-PTO the only option Kioti sells for it is a snowblower.
I know it's not a TYM, but it's as large a machine as I can think of with a mid-mount mower.
   / Largest tractor with a belly mower. #13
The only downside to the Bobcat machines is that they're equipped with their own loaders and backhoes, and the FL7 loader can't compare to the Kioti KL4030.
   / Largest tractor with a belly mower. #14
Looks very similar in size to a T25. it might weigh just a tad more than the T25 from specs I find online
   / Largest tractor with a belly mower. #15
We bought an old farmhouse and 45 acres. About 30 is hay field which I plan to lease to the farmer neighbor indefinitely. But we have about 13 acres of mature woods and about 2 acres of lawn.
I’d love something big enough to haul and lift brush and logs. And mow my lawn. The problem with a 3 point mower is how long it makes the entire unit.
I saw a guy down the road with a decent sized new Holland, with a belly mower. That’s why I asked. I always wanted a TYM bc of the lack of emissions and cost
Take the loader out and use the 3 pt finish mower. These tractors are very maneuverable. You would amazed the tight places I've used my tractor, it's equivalent to the Branson/TYM 3515R.
   / Largest tractor with a belly mower. #16
If length is the issue, get a flail mower.
I find more often that length is a benefit because you can back up and cut under low hanging branches and other things that you couldn’t drive the machine over.
   / Largest tractor with a belly mower. #17
It's just a hair smaller than the 15 series. The T25 is a great machine, but it's Kioti equivalent would be the CX2510.
Just for reference my JD 4320 with 48 engine HP and 40 PTO HP has a 72 inch belly mower. Now I understand that all of the 20 series at that time offered the belly mowers and I think the 4520 @ 55 HP? and the 4720 @ I think 59 HP? offered that. Now this is the 2006 time frame that I am referencing. The JD rep told me they did sell very well and they discontinued that option.
This is the size I’d be interested in.
   / Largest tractor with a belly mower. #20
I have watched someone mow lawn/yard with a JD 2038R & 60" deck and to me it doesn't look like a very efficient way to mow grass!
Just my opinion...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2013 International PayStar 5900i Heavy Haul Truck, VIN # 1HSXYSJT8DJ321464 (A57453)
2013 International...
2005 Ford F-350 Reading Service Truck (A56858)
2005 Ford F-350...
20' Sea Container (A55272)
20' Sea Container...
UNUSED AGT INDUSTRIAL SSHH680 HYD HAMMER (A58376)
UNUSED AGT...
