TODAYS SEAT TIME
/ TODAYS SEAT TIME #13,701
Moving wood around to cut up into firewood. Hit a milestone while doing it. Had no idea when I bought this Kioti that I’d put as many hours on it as I have in just over a year.
/ TODAYS SEAT TIME #13,703
/ TODAYS SEAT TIME #13,712
Nice split window coupe. Very nice indeed.
/ TODAYS SEAT TIME #13,715
That looks great! What implement did you use?
Thanks! I do take pride in my work, and I really wanted to make sure my friends mother was happy.
Land Plane to lift the vegetation and Tine rake to separate the sod from the gravel. I was able to relocate the dunnage behind the fence.
Once the vegetation has been removed, the land plane finishes the job. Sometimes I'll use a chain harrow to smoothen out areas or compress with the tires.
The land plane and tine rake combination has been my go to lately, but I have reconfigured to the box blade at times when I need to relocate a good volume of gravel to another area.
/ TODAYS SEAT TIME #13,718
I'm still on the job doing some work for a customer friend, yesterday my nephew and me, split a LOT of wood for him, we also helped him put a bridge over a creek.
We had to snake some long heavy I-beams back through the woods and here's how I did it,
It was a long day but at least we got a lot done.
SR
/ TODAYS SEAT TIME #13,719
Used the tractor as a work platform to build a "Mouser Motel".
We have a few hard working mousers who happen to be feral. Since they keep the local mice population well under control, the least I can do is keep 'em warm and dry in the winter as payback.
I bought (4) black totes at $10 each from HD. Lined an IBC tote with 2 inches of rigid foam, plus some straw for added insulation. It's anchored to a pallet for easy moving and to keep it upright.
Everything other than the four totes was re-use of material on hand, including the 2 inch foam board and the IBC liner left over from making firewood storage bins.
Now to find out if they'll use it?!
/ TODAYS SEAT TIME #13,720
Used the tractor as a work platform to build a "Cat Condo" or "Mouser Motel".
Now to find out if they use it?!View attachment 1833226View attachment 1833227
Nice job!!!
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
3-Stage Forklift Mast with Forks (A59228)
3-Stage Forklift...
