My experience with open rock lined ditches is that they tend to fill with earth until the rock is buried![]()
Nice Mr. 4570. Looks like you thoughtfully included a rock 'curb'!
Suspect the clueless will not be able to drive out of that ditch...pretty substantial.
My seat time was a continuation of my head scratching and hair pulling of the last couple of days.
I'm going to be replacing the front tires on my Branson 8050, after looking up all the facts and figures for my existing fronts which have always had a bit more lead then I liked.
When disengaging 4wd even on packed gravel there has been a jolt through the drive system. So yesterday I started measuring the actual rolling circumference of my front tires and comparing to the published values. Then I lowered the air pressure from the 30 psi I've been using in them, lowered them to 25 psi and measured the rolling circumference then lowered it to 20, and then 15 psi, when disengaging the 4wd there was actually a slight pause in the rotation of the front tires as the rears unwound it got less and less as I dropped the front tire pressure. Then I went back to 25 psi and scooped up a bucket load of gravel which put a good bulge and squat on the front tires and that did away with the front tire lead,engaging and going out of 4wd to tire hesitation or jump.
So researching the new front tires for my Branson 8050 it has Titan Hi-Traction lug 8 ply 11.2-24's on her now.
They are starting to split in the center on one. And Titan has lost a lot of faith in our area the last few years.
It looks like I finally narrowed it down to either a BKT Ridemax or Alliance Multi use 550's in 300/80R24. Got to call a couple of places Monday and see were I go from here.
Not looking forward to those calls.$$$$$$$
Just what I need, another enticing photo of a 3-point splitter.I'm headed to a money making job tomorrow,
Like today, it's going to be another sunny 70's day tomorrow too, so another nice day to be working out.
SR
The tread is half wore out, new they were supposed to be 134", at 30 psi they were 128", 20 psi was 126", 15 psi they were down to 123".
Got my new ones ordered today getting a set of BKT Ridemax IT 696 in 300/80R24 with a spec'ed loaded rolling circumference of 129.8".
$503.20 each from one of my local tractor dealers, found them online at Pete's Tire Barn for $493.66 each, their closest store to me is Rutland, so 15-20 minutes is nicer then an hour and a half.
Don't come in here tomorrow, because you will probably see it in action! lolJust what I need, another enticing photo of a 3-point splitter.![]()
It could very well be, have you tried lowering the air pressure to get a distinctive bulge in the front tire and see if it helps.Thanks. That's interesting. I have an L3010 which seems to have to much lead. 4WD gets bound up even in the woods. Often need to put in reverse to shift out of 4WD. My M5640 will go any where in 4WD and hardly ever has any resistance at all shifting back to 2WD. Both handle well but the M is a heavier tractor and may not need the front wheel lead ?? Not sure how that all works except that the fronts are pulling more with the lead.
gg
My fronts are only half wore out but one of them is starting to split in the center of the tire. And it's most work is in the winter with chains on half the time I'd just as soon take care of the issue now instead of in a snow bank in January. The sidewalls have been checking and cracking for several years. That seems to be a common problem I'm hearing about with Titan R1's on the front axle of the 4wd.Interesting...
Just read my Kubota MX6000 - Hydro manual again and there's no mention of normal operation REQUIRING coming to a stop to shift in or out of 4WD.
It does mention coming to a stop and try going Fwd or Rev, else try turning the steering wheel if difficulty with 4WD shifting.
I may have similar lead. I would have called it "windup or tension" on the MX. Most of the time, from habit now, I stop the tractor and rock it, inching it back, then inching it forward to disengage 4WD.
It easily drops INTO 4WD without issue while underway at low speed.
Mr. Lou, this thread is interesting. With 1200 hours, my tires are wearing, but not EOL yet. I normally mow in 2WD, but with 12 acres to mow tomorrow, I'll have time to play with different front tire pressures and effect on 4WD shifting to see if I can find a sweet spot.
Until this thread, and Mr. Gordon's comment, I thought the need to "stop and rock" to disengage 4WD was "normal"!
Maybe this will help you decide? lolJust what I need, another enticing photo of a 3-point splitter.![]()
