Brush cutter gear oil leak
/ Brush cutter gear oil leak #1
TVZ
MF 1726E
My King Kutter brush hog is losing gear oil from the gear box. It's not coming out around the gear box on top of the deck. Any idea where it would be coming out?
/ Brush cutter gear oil leak #2
I'm confused. Leaking oil should be pretty easy to trace. Bottom/output seal, input seal, cover gasket or fill/drain plug. ?
/ Brush cutter gear oil leak #3
Pump the gearbox full of grease and don't worry about it.
Well, you see, I don't know the first thing about the seals, where they are, how to check them, etc.. I'll watch some YouTubes about them. Thanks.
Really? You mean grease like goes into the grease fittings? Just shoot it in the gear oil fill-hole? I like this idea!
Any further advice on doing this? Fill it all the way up?
/ Brush cutter gear oil leak #6
Some will say use corn head grease, personally I have pumped 2 gearboxes full of regular off the shelf grease and have never had another problem, pump a cartridge full in the fill hole of your gearbox and about once a year whenever you do maintenance on your mower pump a little in the gearbox, you will be fine.
/ Brush cutter gear oil leak #7
If grease filled brush hog gearbox was trouble free & the way to go, I wonder how come they are not designed that way to start with?
To me it sounds like a bit of a band-aid fix...
/ Brush cutter gear oil leak #8
Feel the top of the stump jumper...is it oily up there? The bottom seal is an easy job once you get the stump jumper off.
  • Good Post
Reactions: TVZ
/ Brush cutter gear oil leak #9
Yep a band aid fix that will last as long as he owns the cutter.
New/Unused Landhonor 100 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
UNUSED INDUSTRIAS AMERICA R2424 OFFSET DISC HARROW (A62130)
UNUSED INDUSTRIAS...
2017 Forest River Travel Trailer (A61569)
2017 Forest River...
Yard Machine Riding Mower (A61166)
Yard Machine...
2010 Deere 318D (A60462)
2010 Deere 318D...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
