hyd loader joystick rod end repslacement
   / hyd loader joystick rod end repslacement #1
kenny quick
1986 kubota 23.5 /1996 ford new holland model 1920
2040 qt bush hog loader with a 25h439938control vale joystick rodends worn out looking for the right relacement
   / hyd loader joystick rod end repslacement #2
Welcome to TBN!
Is your cable control? I only see a 2045 and 2047 model. Which part on the valve or joystick? Pictures would help
   / hyd loader joystick rod end repslacement #3
Just measure them
my rod ends are similar to chalmers 1a9347 and 1a9348 my pieces are worn out one ball is a nut with corners ground off i was wondering if anyone had a bush hog loader with acontrol valve 25h43938 with a joystick sure could use a picture of that joystick
   / hyd loader joystick rod end repslacement #5
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
MULCHER (A58214)
MULCHER (A58214)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
