Is this normal?
/ Is this normal? #1
AlbertC
Perry, GA
New holland 3930
I have a New Holland 3930 that I use mainly for cutting grass in pastures. When I get in A particularly thick area, I notice that the engine will start to bog down and smoke comes from the exhaust. Usually I just hit the clutch to slow down until I get through the thick section and everything returns to normal - ie no smoke.
Is this smoke normal or does it indicate a potential issue with my tractor?
Thanks
/ Is this normal? #2
Diesels produce soot under heavy load. Normal, but you might want to consider what your asking that engine to do.
If a gasser, then that's different, usually burning oil / rings issue.
/ Is this normal? #3
From my search, this units you have is a diesel... It's normal to a extent, your RPM goes down causing a imbalance with the fuel to air ratio causing black smoke (unburn diesel)... I would make sure your air filter is clean, clogged air filter would cause this to be more pronounce and if it's still the case once this is done it's normal. Give this little guy a chance to keep up with the task.
/ Is this normal? #4
Under a heavy load black smoke from a diesel is common. If you are slipping the clutch to slow down it will not last long. I am assuming that this is a gear drive tractor and not a hydrostatic. The proper course of action would be to down shift one gear and continue mowing.
/ Is this normal?
So am I overtaxing the engine? Should I raise the cutter and go over it twice, slow down. Etc. I just assumed the engine could handle it
/ Is this normal? #6
Either one will work slow down or raise the mower.
Also how much are the rpms dropping just a couple of hundred or several hundred, just a couple of hundred would be no problem if you are running at pto speed or a bit above.
/ Is this normal? #7
Its normal. The governor is asking for more rpm than the motor can provide, so it's excess fuel being burned.
/ Is this normal? #9
Good Morning AlbertC,
LouNy has it right ! When I am mowing through thick stuff and am pulling a steeper hill, I will drop down one gear and that usually takes care of it. As some one mentioned, you dont want to slip the clutch !
/ Is this normal? #10
Agree with the others drop a gear.
For really small patches I use the foot throttle to speed up rpms right as I hit patch then let off
/ Is this normal? #12
I run into this problem as not only do I get into thick patches, but I am often climbing relatively steep slopes when the engine bogs under load. I never ride the clutch.
I gear down.
I use the foot pedal to add more fuel/power
I cut a smaller path where I know this is going to happen.
I find that one has to learn the limits of the machine, the lay of the land, and the grass/weeds/growth being cut....
/ Is this normal? #13
Nobody asked - What RPM are you running at for mowing? Your engine RPM should 1800 to have a 540 RPM PTO speed.
/ Is this normal? #14
What range L-M-H, what gear and what RPM?
/ Is this normal? #16
As mentioned, drop a gear in the thick stuff and keep the RPM's up. Or your next post will be "How much does it cost to split a tractor and replace the clutch?"
/ Is this normal? #17
Why my Kubota's have hydraulic shuttles as in NO DRY CLUTCH. I can slip the wet pack and not hurt anything. I would never have a tractor with a dry clutch.
/ Is this normal? #18
I used to do work for an Ace hardware that had a clutched tractor. Put 3 clutches in it over 2 years. They’d put a new guy in and he’d burn the clutch up in one day! After the third one they replaced it with a hst machine which I suggested after the 1st clutch job. lol.
/ Is this normal? #19
Speaks much of the mentality of the instruction the operators got.
/ Is this normal? #20
Thanks
After having a peek at several of the posts today I am further convinced that tribal knowledge of things mechanical has nearly come to an end for many and does not exist at all for some. You don't ride clutches they aren't speed controllers, black stacking under load is normal for diesels you need to downshift, tractors do over heat and unattended to you will warp the head, a squeak means a bearing is probably going out and you need to fix or grease something etc. These things are just simply tribal knowledge I learned with instruction from my Dad and others before I was between 5 and 10 years old. I passed them on to my own son. People that don't know these simple basics are way behind the curve, have too much to learn, owner's manuals simply can't cover all they don't know and they should probably spend their money on hiring work done instead of owning a tractor.
It is a sad state of affairs that we are now in. No wonder people in North Carolina have fallen apart when cell and internet service ended. I once doubted the disastrous forecasts of a post-apocalyptic world but now I don't. Just too many people don't know how to do things that are essential to recovery and survival. Truth hurts.
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2019 John Deere 4044M (A62177)
2019 John Deere...
207279 (A52708)
207279 (A52708)
2003 Ford F-350 Flatbed Chemical Sprayer Truck (A61573)
2003 Ford F-350...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2020 INTERNATIONAL...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
