SSQA issues
/ SSQA issues #1
tshelton1
Mahindra 25xl
Long time lurker. First time posting. I'm having issues with putting SSQA brackets on my tractor. The brackets that I bought offline are to short to fit snug in the plates on the implement. They leave about 1"-2" gap on the bottom when hooked on the implements. I have looked and the plates on my implements are the standard SSQA size.
The measurements on all the tractor brackets that I can find online are not correct. The back flat part needs to be roughly 16" and overall hight should be roughly 18". I attached a picture of the measurements of the ones I'm finding online. Has anyone else had this issue. Thanks in advance!
/ SSQA issues
Thanks for the information! I may just have to modify the ones I have. I can't believe it's so hard to find a a set of weld on brackets for the tractor that fit tight. Does anyone have any they have used that worked out well?
/ SSQA issues #6
+1 If they don't fit, send them back and get something correct. ruffdog posted links to the specs. They are readily available to double check on the web, too.
/ SSQA issues #8
I bought this exact SSQA w/ the 3/8 plate. I have about a 1/4" gap at the bottom.
The same 1/4" gap with a new skid steer bucket.
I'm going to tack in a plate to fill that gap.
I'll measure mine and see if I have the same dimensions.
/ SSQA issues #9
Why fix it? Return it and get something that is correct. No good reason to encourage defective crap to be made...
/ SSQA issues #10
I purchased a set of SSQA adapters online that are the size pictured. I also purchased the SSQA plates for 3 different attachments. Everything fits as it should, there is about a 3/8" gap at the bottom as it should. The only issue I had was the springs that put pressure against the pins to hold the bucket in place were weak and I replaced them with OEM Bobcat springs and everything's works as it should.
/ SSQA issues #11
I am curious as to why you think there should be a 3/8" gap. That would bother me and I would shim it. In my mind there should be no gap in any of 3 places (see arrows); between face of SSQA adapter and SSQA plate, between face of pin and SSQA plate slot, and between angled surface of SSQA plate and adapter for a proper fit.
gg
/ SSQA issues #12
I bought my conversion stuff from Vevor, on sale.
I had to covert my loader for DuAl quick attach to SSQA, (quite a bit of thinking) and someone gave me a 30 yer old kubota bucket that I had to cut the pin-on brackets and stiffener off to add the QA plate.
Having everything fit tight/perfect is not as critical as having the attachment LOCK ON tight to the loader.
Every attachment I have has a slight different width, AND is 'slightly' different where the locking pins go into.
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
(32) FLOOR TRUSSES (A62131)
(32) FLOOR TRUSSES...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2022 Case CX145D SR Hydraulic Excavator (A61567)
2022 Case CX145D...
UNUSED KUBOTA M6912 BRUSH GUARD (A62130)
UNUSED KUBOTA...
