How to remove pin
/ How to remove pin #1
Morning Wood
Gold Member
I’m borrowing a yanmar cbl 40 from a friend. The deal is I grease and change oil. I was not able to get the thumb cylinder at thumb to take grease. Fitting is ok. I did everything I could do. Next step is to remove the pin. Before I start bashing on things I’m wondering if the pin has caps or something on it. The retaining bolt comes out fine, but the ends of the pin have little threaded holes. Are those caps that need to come off to access the pin or is it the pin itself?
Thanks,
Nick.
/ How to remove pin
I will add that the cylinder does move around on the pin, so I’m assuming the pin is rusted up on the sides to the thumb.
/ How to remove pin #3
Looks like you need to remove the bolt in the last picture and it should come out with some persuasive hammering
/ How to remove pin #4
I usually try removing the grease fitting and drilling the old grease out behind it before I remove the pin. Also put the grease fitting on the grease gun while it’s removed and see if it flows through easily. I’ve seen them get stopped up.
/ How to remove pin #5
Might try cleaning out as much old grease as you can, then make a half damn on the hole with grease. Spray penetrant in the hole, replace zerk and try and pump grease. You'll get some resistance, but hold pressure on it. Once the liquid starts through, grease will follow. A decent gun will produce 12K psi, so should push the liquid through. I've had a 99% success rate using this method.
That is, unless the bushing has spun away from the hole.
/ How to remove pin
Fitting flows. I took it off and sprayed penetrating fluid in there with compressed air. Nothing. I’ll try scraping out the hole. Kinda crappy access.
/ How to remove pin #7
Once keeper bolt is out nothing should be keeping pin from moving but rust.... Did you try running a small drill bit (under size- by hand) down pin to clear any old grease out of passage?
/ How to remove pin #8
A Yanmar CBL 40 ? Now there is a rare bird. And reputed to be as good as they are rare. Supposedly they were strong and simple construction quality.
Yanmar made them for a long time, wonder if they still make them and where would a person find a new one? I tried to find a new one back when we were looking at TLBs & bought the Kubota.
That pin might not come out easily. I've had some luck on similar pins with an old heavy two-jaw puller with long enough legs. The center of the puller will sometimes push on pins enough to get them to move. It usually requires torch heat + hammering, too. The counter sunk hole helps locate the puller center bolt
I wonder why that hole is threaded?? Could it be that a zerk could be threaded in there to some advantage?
Have you tried one of those hammer impact oil&grease injectors? I got one from Amazon recently - a $50 Lincoln 5805 that says use light oil instead of grease - but have not tried it yet & have no idea if it will work.
Maybe that pin just has to stay there....After all, you say that the cylinder does turn on the pin, so maybe a hammer impact grease gun like the Lincoln will lube the center and you can just leave the pin stuck.
BTW, here is an old adv. for the CBL 40. From about 2008.
rScotty
/ How to remove pin #9
Yeah, the CBL40 was amazing when it came out. A JD110 competitor, IMO.
Turbocharged version of the venerable Yanmar 3-cylinder 1.5-liter diesel, similar to those NA 3-cyls I had in my old JD4300 tractors.
They made it for less than 10 years, I estimate, possibly longer for non-US markets. Photo is from World Ag Expo 10 or 15 years ago.
/ How to remove pin
It’s really a sweet little machine. Very solid. My ford 1720 is a joke compared to it. This one only has about 475 hours on it. I was able to get the fitting to take grease and I’m not going to bother with trying to get the pin out. We can cross that bridge when we need to. Thanks for all the suggestions. I went back in and cleaned out the hole better with the grease fitting removed. That did the trick.
/ How to remove pin #11
Do you have the CBL40 3-point hitch option, and do you ever use it?
/ How to remove pin
It has it, but I don’t think the backhoe has ever been off. Although I did see a york rake kicking around so it might get taken off every once and awhile. Not my machine.
/ How to remove pin #13
Would like to second the use of an impact tool with penetrating oil. first briefly heat the zerk, then run two or three rounds of oil with a hammer. return the next day, repeat if necessary, usually works.
/ How to remove pin #14
Thanks,
Nick.
I've not read all the replies so maybe this is a repeat, but
I'd never presume to do ANY work on a borrowed machine without the owners express agreement.
I know I'd be pissed off if someone, in the process of "helping me out" did some maintenance on my machine and something went wrong.
Just a few words of caution as I don't lend tools or machines. Anymore.
/ How to remove pin #15
What has kept me from doing that with the impact tool I bought is that with a light penetrating oil, a cylinder piston and a hammer .... the whole setup begins to look to me a lot like a one shot compression ignition diesel.
rScotty
/ How to remove pin #16
Thanks,
Nick.
I have an old K-D 416 device that is a piston/sleeve you disassemble, fill with light oil, put against a STRAIGHT grease fitting, and hit with a hammer. It blows out the old, hardened grease. It's expensive for a tool you will rarely use. I've had mine since the early 70's. It has saved me a lot of work a few times over the years. It's still available, look it up.
/ How to remove pin
You should have read all posts. The agreement was that I do maintenance on it as payment for borrowing.
/ How to remove pin #18
Nah. Takes all the fun out of it.
But I did read yours, you should too.
It says "grease and change oil", not "maintenance". To me those are different things and I would not go into anything else without further consult.
But, that's me.
Have a happy.
/ How to remove pin #19
Thanks,
Nick.
I worked many years as a field service heavy equipment mechanic. Heat the pin boss with a good torch , get it good and hot, oil the ends so it draws the oil into the space between the pin and pin boss . hit the pin boss with a heavy hammer, then try flush greasing. If the pin boss does not have grease fittings you may want to drill and tap , and add grease fittings to the pin boss. most pins I have worked with in the past were drilled to provide lube to the cylinder end and not the attachment, grease goes to the middle of the pin and is forced to the outer ends. . after torching out a few of these I started adding grease fittings .
/ How to remove pin #20
Why would you try to do this when pin is stationary in boss.... Actually what you really want to do is clear grease passage in pin so end of ram is lubricated on pin....
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
John Deere Cotton Picker Catwalk Floor and Railing (A63116)
John Deere Cotton...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
2015 SKY TRAK 6036 TELEHANDLER (A59910)
2015 SKY TRAK 6036...
2008 CATERPILLAR TL642 6600 LBS TELESCOPIC FORKLIFT (A64047)
2008 CATERPILLAR...
