hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,743
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
I currently have Kubota L5740 and am considering adding a 100hp tractor of some sort. I want to be able to run a 15' batwing mower, and need more HP to drive an 84" hydraulic snow blower. The 5740 falls short on HP and weight for these tasks.
One area I'm focusing on is the transmission. The terrain here is very steep and uneven, and the HST in the L5740 has been great for that. But I'm concerned that a "manual" transmission will be a big step backwards. There appear to be two types in current tractors:
Synchronized gears, but clutch-to-shift. They all seem to have a clutch button on the shifter so you can just hold down the clutch button while shifting rathe than use the clutch peddle, but there will still be a pause as you shift. I'm thinking that when going real slow on steep terrain, I will actually have to brake to a stop, shift, then start up again. I'm sure I will get used to whatever, but this sounds less desirable.
Power shift gears where all the clutching is automatic and without loss of drive power, much the way an automatic transmission in a car shifts. This sounds much more desirable for my application.
All of them have foward-neutral-reverse clutchless shifting, often called a shuttle shift.
For range shifting, most require clutching, and perhaps even coming to a stop. But some have clutchless power shifting of ranges too, and even automatic reselection of the primary gear to match speed when you shift ranges. Some have just a single high/low gear range shift that is clutchless, but the individual gears are still clutch-to-shift, and there is typically a second manual shift range control too.
In a perfect world I'd just get powershift everything and I think be quite happy. The problem is that the smaller 100hp range tractors like the Massey 4700 series and the Kubota M4 series are only available with clutch shifting. Massey has a single high/low range power shift, but gears and ranges are otherwise clutch to shift.. I think Kubota is all clutch to shift. To get power shifting you need to move up to the Massey 5700 series or the Kubota M5 series. Both look like great machines, but probably overkill in all other ways for my needs, and of course a good bit more expensive.
Any thoughts on this, including any other thoughts on Massey 4700 vs 5700, and Kubota M4 vs M5 series machines?
