   / Your last generator Maintenance Run #7,021
That's quite a few hours for $299 generator, so it probably owes you nothing?
I think propane operated generators will not have any carbon buildup issues at all.
Gave this “new to me” girl a workout…and then an oil change with the addition of a Magnetic dipstick from Goldplug. 😉
View attachment 1344832View attachment 1344833
Team Red - is growing the Lineup ! (y)
That 3000 is a nice size - but it's good to have the handle and wheel kit. Buddy 'o mine used to run one @ racetracks - deadlifting was nicer with 2 people.
Goldplug, I'll have to check what they cover (re. mine); thanks for mentioning that.
Rgds, D.
My little $299 Champion 1500W quit at night a couple of weeks ago. Funny, because I had just changed the oil and it barely used any before.
I went out and Filled the Oil thinking it was Low, nothing. Switched over to the 4500w and finished the movie, shut it of and went to bed.
Next day, I tried again to start it, found no compression after removing the Plug. So i tore it down to see if a Stuck/Burnt Valve might be happening, nothing.
There was a lot of Carbon built up, cleaned it up, bolted back together. Cleaned the Spark Arrestor, poured some gas in the plug hole. It would sputter but still Very Low Compression (Thumb over the hole).
Next weekend, New Plug in hand, I filled the Combustion Chamber with Carb Cleaner let it sit 15 minutes, Pulled a couple of times, pop, my thumb would get blown out of the Plug Hole. Screwed the Plug in and it started, smoking heavily. Held it on the Governor for a bit to clean out my Cleanings, shut it down, added New Oil, Boom it started again. But smoked heavy. Ran for 1/2 hour and checked the oil, added (it was real low). Fired it up again and went in to watch a movie.
Looked out a few times smoke pouring out of it. Movie was done 1 1/2hrs, I went out to refill the oil, and it was running Clean and Clear. As it is today without burning any oil.
The rings must have been Stuck, the Combustion Chamber cleaning and Carb Cleaner, hard run on the Gov, must have loosen them out. Runs just like New with 1650 hours on it.
Nicely played recovery (y).
You obviously know your way around engines... but I'll say it anyway...... I do tend to forget the air-filter on my portable gens - doesn't seem to readily come to (my) mind to check, compared to road vehicles.
Fuel quality.... that's hurting many of us, it seems. Thinking of your carbon story, reminds me of turning a buddy of mine loose with Seafoam, a dozen or so years ago..... he'd flow to the East coast, to help his brother drive his beaten-on van back to Ottawa for a funeral. Stops somewhere like New Brunswick, and decides to dose his brother's van (dump into vacuum line) out back of a little Parts store. Coupla customers walked around the corner of the store, while they were doing this - the other guys thought the van was on fire - so much black smoke was hanging in the air !
Never looked before.... now I'm curious what I may/not have for vac ports on mine......
Rgds, D.
   / Your last generator Maintenance Run #7,024
I got 200-300 hours out of a 1800w Chinese inverter generator 15 years ago, and thought that was reasonable. 1600h is remarkable.
I have since moved to Yamaha inverter generators (1800w and 3000w).
I remember a wrench I knew, back when I was a pup.... describing heads coming off med-duty trucks of the day, running exclusively on propane - basically looked like they just came out a box, from the factory.
IIRC, natgas burns slightly cleaner - nothing we'd notice in use, as you'd probably need controlled lab tests, to see the difference wrt. propane.
I'm leaning towards propane (dual fuel) on my next portable gen. The only storage issue with propane, is the portable tank expiring !
Rgds, D.
   / Your last generator Maintenance Run #7,026
No, it sure doesn't, But no use burying it yet. Runs great, Oil Changed every 100hrs, Foam Air Filter needed cleaning often with that Oil Blow By.
Actually have an Older One without an Hour Meter, did the same tune up, and it lives again. Surprised me that the older 80cc engine was actually a Hemi Spheric design, with a much better Valve Train.
I have found that the Cheap Champions are much less costly than fixing my Hondas when they break. So I have just been doing that. It was $600CDN for a Rectifier for my 4000 Honda or $500 for the 4500 Champion 20 years ago, and it is still running, when I am doing any Building
Good value for money, seems to be the trend with Champion. They have modern designs now (inverter, quieter), but many people have had similar good service. At least one guy on here was given a really high-hour vintage Champion (construction use) for free - "Not Running". Just needed a valve-adjustment, as it had never been done.
Electronics add failure points. Same in automotive.... even MBenz doesn't have much of an electrical warranty, last I checked. Inverter gens have impressive specs, but are not inexpensive to fix.
Rgds, D.
   / Your last generator Maintenance Run #7,028
Rgds, D.
Not cheap….but incredibly well made!
I did have a look, after you first posted. Maybe just weak keyboard-foo @ my end, but I could only find two listings for Honda (no other Manuf. listed for magnetic dipsticks).
Other than cost, I suspect another reason OEMs don't include magnetics is to avoid people freaking out, if they find a tiny spec of ferrous material on a magnet - which may be nothing more than a tiny bit of swarf that wasn't evacuated @ factory.
One place TBN has value for most of us.... accelerates learning about complex (or simple) fixes for relevant problems. Saves Time (aside from money), which I value the most. Cheat codes - I remember reading a review (Amazon) on a Champion gen, one of the smaller recent ones..... guy included the actual PN of the magnetic dipstick he sourced for that new gen he bought. If it's a Game You Are Interested In (very subjective), then cheat-codes make it a great day !
Rgds, D.
2019 Komatsu WA380-8 Wheel Loader, S/N A75147, PIN# KMTWA130TKNA75147, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2000 TRAVIS BODY & TRAILER, INC. 39 END DUMP TRAILER (A58214)
2000 TRAVIS BODY &...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
