JD 5300 Rear Remote...No Float Position
/ JD 5300 Rear Remote...No Float Position #1
jgbanshee
Gold Member
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have both a JD 5300 and 5210 both with a single rear remote. The 5210 has float but the 5300 does not. Does the 5300 valve only need the longer cap to allow spool movement for float or will a longer spool be needed also?
/ JD 5300 Rear Remote...No Float Position #2
It requires a whole different valve. You can't just swap some parts.
/ JD 5300 Rear Remote...No Float Position #3
Yes this requires a longer spool for the 4th position and detent assembly.
No clue if parts for 5210 would work on 5300. Whole valve might mount in same place.
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
INGERSOLL RAND 80 GALLON COMPRESSOR (A65643)
INGERSOLL RAND 80...
Gravely Rotary Cutter Attachment (A65640)
Gravely Rotary...
Camco Running Gear (A66408)
Camco Running Gear...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
