woody
- Joined
- Sep 20, 2010
- Messages
- 1,171
- Location
- Central Alabama
- Tractor
- Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
Okay guys I'm digging up an old thread, the cheap DCCA wire got me but it did last 2 years and did a good job. But I hauled some limbs and stuff and when I went to dump it would not dump the second load and when I connect to my truck with the Anderson connector it did not make a difference so after using a jump box to dump it I go home and put the battery on charge. The battery charger after about 30 minutes said the battery was bad, so I connected a different charger to it and it eventually gave the same indication, so I replaced the battery and tested the 7 way plug, yep blown fuse and I replaced that. My grandson called and his car was broke down so I connected up my tilt bed and go get him after loading his car and driving just a few miles to unload the battery was low so I connected the Anderson connector and it was no help so I used the jump box again and when I got home this is what I found.
The wires practically fell apart when I touched them and the breaker feels like it is corroded inside when I try to move the lever. This set up has worked so well for 2 years I will be trying to find something to replace it with but it will not be DCCA wire. Hope this helps someone.
