Yanmar F15D oils and intervals
   / Yanmar F15D oils and intervals #1
kayno
Yanmar F15D
Hi all,
New here. I recently bought a yanmar F15D and I'm having trouble finding information on it. Just wanting service information around what oil grade/spec I should use for the engine and transmisson. I'm in Australia so I was leaning towards using 15w40 for the engine, I just want to be more cautious with the trans. I've heard you can also use engine oil in there aswell? As it doesn't damage the wet brakes.
Cheers.
   / Yanmar F15D oils and intervals #2
Hi all,
New here. I recently bought a Yanmar F15D and I'm having trouble finding information on it. Just wanting service information around what oil grade/spec I should use for the engine and transmisson. I'm in Australia so I was leaning towards using 15w40 for the engine, I just want to be more cautious with the trans. I've heard you can also use engine oil in there as well? As it doesn't damage the wet brakes.
Cheers.
Do not use 15W40 with the Japanese tractor engines, especially Yanmar.
The so called American Iron tractors were made for it, not the Asian tractors. Asia machines are built to JIS standards. 15W40 retains the heat longer in the engine on JIS type engines. In time of heat and working the engine hard, the heads begin to warp. Also the engine runs poorly and black soot becomes an issue.
5W30 winter, 10W30 summer, extreme heat SAE 30.
Hydraulic fluid is JDM J20C (Hygard) or TF500A.
If you need the manuals for free, they are on the YTOG.
Just click below.
Just click below.
Cheers for the reply mate.
I've found a gulf western UTTF oil which meets the j20C grade so I'll look at getting some of that.
As for the engine oil, I'm assuming you mean oil that meets the JASO requirements for jap produced engines? If a 15w40 oil was to meet JASO DH-1, which I'd assume would be the grade these engines fall under Would it not be compatible? I was more just looking into operating temp ranges more than potential heat soak
Would you suggest mineral over semi synthetic? Something with a high tbn, ash and zinc %?
   / Yanmar F15D oils and intervals #4
Do you have the Rotella brand out there?
   / Yanmar F15D oils and intervals #5
   / Yanmar F15D oils and intervals #6
   / Yanmar F15D oils and intervals #7
The same engines in the YM, F and FX series are in the John Deere machines.
   / Yanmar F15D oils and intervals #8
   / Yanmar F15D oils and intervals #9
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
207270 (A52708)
207270 (A52708)
Kubota L3130 (A53317)
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
