Where do you buy tires? What brands to avoid.
   / Where do you buy tires? What brands to avoid. #101
Yep they changed the bar angle, when it gets mounted on a rim it will not look as much narrower as it does just sitting next to the older tire.
   / Where do you buy tires? What brands to avoid. #102
Not crazy about my last carlisle purchase. They changed their tires but call them the same thing. And many sellers are using the old product image so you don't get what you see. Here are my old vs new tires.
Both Carlisle farm specialist r1s. Both 8-16s. Both fully inflated. What gives?
Are you sure they are Carlisle and not Carlstar?
Carlisle Branded Tires Are Now Carlstar
And does it widen out when mounted and weight put on it?
I see the difference in the bar angle but the width sure does look different to me.
   / Where do you buy tires? What brands to avoid. #104
That pic is mounted and aired up. It says CARLISLE on the tire, although I bought them right before they changed to carlstar. Says Made in India. so i looked it up on the Carlisle website. Same model, Same listed Size, Different Sku #. The tire is more narrow, But is listed with a slightly higher load rating (160 lb more). And higher max inflation. (42 vs 28). I think i only put around 30 in them so ill put more in being a narrow tire.
   / Where do you buy tires? What brands to avoid. #105
I dont think you can even get the old style anymore. What ticks me off is there is no depiction of the new tire on the site. They still picture the old style! Not what you get.
   / Where do you buy tires? What brands to avoid. #106
They may well be closer to each other in size after some use. Tires do stretch and change shape slightly under pressure and torque. When I replace ine tire the size specs drive my purchase more than brand.
   / Where do you buy tires? What brands to avoid. #107
The older tires did dry rott well before the tread had significant wear. Hopefully these last longer. I do like that they have a higher load rating. They are listed as 8 ply vs 6 ply for the older ones. For whatever that's worth.
   / Where do you buy tires? What brands to avoid. #108
Keep them out of the sun! Tires in shade or indoors last nearly forever.
   / Where do you buy tires? What brands to avoid. #109
I just put a pair of Carlstar tires on my drill and they still have Carlisle and Made in the USA on them.
   / Where do you buy tires? What brands to avoid. #110
This place linked below is local to me but i think they still have a ebay store and ship as well. They have tires up to 20 ply. Ply rating is something a lot of people ignore on tractor tires. Some of the "cheaper" R1 tires nowdays are 4 ply. I personally try to get 12ply or heavier. We had 4 ply on a DEERE that blackberry thorns won out on. Ive never seen a tire before get ruined by blackberry thorns. We swapped them to 12 plys and havent had a issue since.
2020 FREIGHTLINER M2 106 BOX TRUCK (A56129)
2020 FREIGHTLINER...
72'' power rake (A53421)
72'' power rake...
Suihe 20'x40' Container Shelter (A53316)
Suihe 20'x40'...
2017 Nissan Frontier Pickup Truck (A55788)
2017 Nissan...
1990 PETERBILT 320 HYDROVAC (A55745)
1990 PETERBILT 320...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
