Oil pressure light
   / Oil pressure light #1
Willismtn
New holland work master 33
Workmaster 33 Oil pressure light comes on at idle but goes of with increase rpm. New oil and oil filter. Any thoughts would be welcome
   / Oil pressure light #2
More info needed. Did you check the wiring between pressure light and sender? A bad connection will also cause that to happen.
Did you change to a different oil? Some of the new 0-30w synthetics are noticibly less viscous when cold. And is it an OEM or aftermarket filter? Are you willing to change both again?
Is this something that is definitely related to the oil & filter change or have you seen the light flicker before? Any other changes?
The problem with lights vs gauges is we always end up needing a dial gauge reading to know if the pressure light is faulty. It's common for mechanics just replace the pressure sender because it is cheap and most have no way to test it.
rScotty
   / Oil pressure light #3
Also what is the low rpm stop set to, 500 rpm or 850 rpm.
   / Oil pressure light #4
Sometimes the pressure sensor will fail - I've had it happen. Temporarily install an oil pressure gauge to see what's really happening. In addition to oil pump and bearings there is a pressure relief valve spring which can get weak or fail. Troubleshoot before throwing money at your problem.
   / Oil pressure light #5
It’s old. Probably lots of wear Would be expensive to fix. Would it be out of the question to keep it idled high? I’m sorry but I don’t know an easy fix. Maybe others will have better suggestions. I’ve had old cars in the past do that till I traded them off.
rScotty
I haven’t check the sensor, that is next and I’m probably going to get a pressure gauge and check as well. I’m not a mechanic so first time troubleshooting for this weekend warrior
   / Oil pressure light #7
Replace the 'idiot light' with an analog gage. Idiot lights are just what they say... for idiots.
Unit is old and clearance are probably excessive so change to a heavier viscosity oil...
   / Oil pressure light #8
Updating my answer in #2 a week ago....
Did you check the wiring between pressure light and sender? A bad connection will also cause that to happen. Just trace the wire and tighten any connections. Sometimes just wiggling the connection will fix tha problem.
Did you change to a different oil? Some of the new 0-30w synthetics are noticibly less viscous when cold. Change the oil to something like a 15w-40 Rotella - that's the old standby for diesel engines. And does the engine have an OEM or aftermarket filter? Are you willing to change both filter and oil again?
Question....Is this something that is definitely related to the oil & filter change or have you seen the light flicker before you changed oil/filter? Have you tried just setting the idle a little higher? That is commonly done as engines get older.
The problem with lights vs the old style analog dashboard gauges is we always end up needing the numbers available on an old style gauge reading to know if the pressure light is faulty. And to know if there is a problem or if it is just a case of low idle or lower pressure due to normal wear. If the oil is flowing well, an engine doesn't need much pressure. Most of the internal pressure it needs is generated by the movement of the inner parts and does not show on a gauge.
Finally, those idiot lights often suffer from bad senders. It's common for mechanics just replace the pressure sender because it is cheap and quick to replace - and most have no way to test it anyway.
updated from a week ago,
rScotty
The light was on before I change the oil and oil filter, I purchased the oil for the new holland dealer, they didn’t have the filter so I had Napa cross match with the part number for the oil filter which I got from new holland dealer.
rScotty
Also after I changed the oil was when the light would stay off if I idled a little higher
Westfield Conveyor (A56438)
Westfield Conveyor...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
2014 BOBCAT E32 EXCAVATOR (A60429)
2014 BOBCAT E32...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
