LS 3033H
/ LS 3033H #1
AUSTENNN10
Member
Alto nm
Ls 3033
Could not finds a search box just for LS Tractors so sorry if I am duplicative but where is the Hydro oil drain plug. No diagram in manual.
TIA
/ LS 3033H #2
Should be under the rear axle housing or just in front of it. There could be 2 of them if the trans housing wraps over the drive shaft.
They are usually marked with white paint, but yours could be well worn off.....
/ LS 3033H #4
I'm going to assume G3033 the items labled #7 should be the plugs.
You can go Parts - LS Tractor USA then click on "Look Up Your Part" , use the menu to select your tractor and area of interest.
/ LS 3033H #5
They don't show them in a G3033 book but they show them in a MT225E book. Same transmission. Copper drain plug seals are called "cooper" seals. Lots of typos in the book.
Honda Rancher 300ES Four Wheeler (A64047)
Honda Rancher...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
John Deere 5090GN (A60462)
John Deere 5090GN...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
