Starlink
/ Starlink #4,222
Starlink mini now available - It's a mobile downsized dishy, has anybody tried it?
I'm thinking about ordering it and cancelling my SL RV service. Since they upped the RV price to $150/mo I can make up the difference pretty quickly, even considering the $600 for equipment.
/ Starlink #4,223
pretty sure the mini has a 50gb limit for some reason
/ Starlink #4,224
I thought of that...
/ Starlink #4,225
Yes but I only use my SL RV for camping trips. I think I could do 50G and I believe its something like $1 for each extra gig?
At $30/mo versus $150/mo I recoup the purchase price in 5 months. I will probably put my RV system as "dormant" while I try out the mini.
/ Starlink #4,227
The only internet service I have out here is HughesNet. A week ago I had my system upgraded to Phoenix. Upload and download are definitely better/faster. It's not fiberoptics but it definitely does everything I need.
/ Starlink #4,228
Got notice of a change in terms of service, but it didn’t include details.
An updated Terms of Service will go into effect on 10/10/2024. No action is required on your behalf. Based on your location, changes may include a new name for your service plan.
Thank you for being a Starlink customer and supporting our efforts to deliver high-speed, low-latency internet across the globe!
The Starlink Team
If you wish to discontinue your Starlink service, you may cancel at any time.
Space Exploration Technologies Corp | 1 Rocket Road, Hawthorne, CA
/ Starlink #4,229
The Starlink Team
Got the same email, have to see what happens.
/ Starlink #4,230
Even though i swore i wouldnt get starlink as my microwave unit was giving me enough download speed….. the trees finally matured enough to start blocking my internet reception.
I went to the dark side and i installed the new gen3 starlink.
Install took about 2 hours, due to running wires. Works great. I get over 180 down and 17 up. On average. I chose eve mount, and 100% unobstructed view of sky. If there are outages, i have not noticed.
But i wanted a guest network and a IoT network separate from my main network. So after about 2 days of messing around, i was finally able to disable starlink wifi and pass it thru to my 3 month old modem. Took alot of geek speek to get it all working, but its working great now. Had to reconfigure shop wifi extension and my wavelink antenna to reach other buildings and barn for my wifi calling that i need for my remote area.
I only wish elons modem had options for a guest network.
/ Starlink #4,231
The Starlink Team
There is a link to the new Terms of Service. No way to tell exactly what changed though.
/ Starlink #4,232
Interesting I have the 2nd generation router, I did purchase the ethernet adapter which I plugged into my older netgear router. I now have the choice of which wifi network to connect with either the Starlink or either one of the two netgear wifi's.
It looks like the 3rd generation has the ports to just plug into.
/ Starlink #4,233
The third generation has Ethernet directly, and has a slightly larger and more powerful antenna, with no motors in the mount. To my way of thinking, the new actual router is also a slight step up in performance, due to slightly reduced latency.
Currently, the base kit is on sale in many areas for $299. I'm fence sitting about buying another just in case, and replacing our current setup with the newer hardware.
All the best,
Peter
/ Starlink #4,234
All the best,
Peter
They actually have two "standard" kits;
The one is still the motorized self aiming unit with the Gen 2 router which requires the adapter for the Ethernet port,
and then the "newer" standard which you have to aim which has the Gen 3 router with the built in Ethernet ports
/ Starlink #4,235
The Starlink Team
Same here. The message implies the changes may be location specific.
/ Starlink #4,236
Starlink's site is a bit of a morass to navigate in my opinion.
That's their specifications page that includes older hardware. The order page only includes the newer non-pivoting residential and business antennas, plus the mobile and lite versions;
All the best,
Peter
/ Starlink #4,237
I couldn’t tell what changed in the terms of agreement. They should provide a summary of the changes.
/ Starlink #4,238
Does it really matter? We're kinda stuck with it unless we want to cancel service. And most folks with Starlink have very few alternatives. Corporations have you by the short hairs and can do what they want, mostly.
/ Starlink #4,239
Ain’t that the truth.
/ Starlink #4,240
First thing I do with any service that we have/had is disable the providers router/modem and set them to pass thru. This was the first thing I did to the Starlink as soon as I knew it was working.
I have little faith in the security of the units any service provider provides, especially after seeing how sad security was when we had ATT Fix Wireless. I disable the providers wifi and then pass thru to my router that is setup for two wifi networks. I segregate everything by type of internet access it needs, for instance laptops are on one while network where shared files access is needed and monitoring systems like the solar panels or weather station are on another.
2025 Swict 60in Bucket Skid Steer Attachment (A66734)
2025 Swict 60in...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2019 SDLG L938F WHEEL LOADER (A65056)
2019 SDLG L938F...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
