How to mount a posthole digger
/ How to mount a posthole digger #1
Musdalen
Gold Member
STORY CITY, IA
Ford 8N
I have a rather strange request. I need some ideas for how I can mount a posthole digger on my 3 point. Easy peasy normally. I have always had my digger dangling from a pulley in the rafters. But now I need to haul digger, mower, and tractor to a far-away remote location where there are no rafters (yet). And not even any suitable trees. This is a Frontier 9" auger that is a beast just to drag around in the dust, never mind mount of a 3 point.
I could lighten it by removing the auger and pto shaft, but both are shrouded in pesky plastic shields that are not easily removed.
Perhaps some of you have built a stand or some sort of jig for this purpose. I'd love to hear about it.
Thanks.
/ How to mount a posthole digger #2
When I had a 3 point auger I disassembled the whole thing.
A lot of users here have made interesting jigs, and some also just auger the bit into the ground when storing.
/ How to mount a posthole digger #3
Put the mower on the trailer first, then the tractor with the digger mounted.
After unloading screw the digger into the ground enough to hold it up until needed.
/ How to mount a posthole digger #4
I have my PHD in parts (no safety shields) I mount the main pole to the toplink and hold it up with a ratchet strap attached to the ROPS. Then mount the lower 3 point arms and to the main pole... that holds everything in place so you can mount the drill and PTO driveline. (not sure what to say about safety shields... nothing I have uses them)
I have thought about using the rops and a come-along. But I found a few utube videos and learned a few tricks that worked for me with a little modification. One guy had a simple pair of props that worked well.
My auger is a bit heavier than many, but i was able to set it up without too much trouble once i had a better idea of how to start
@Xfaxman ssuggestionof the hole was mentioned too aandI may try it. Tomorrow, I'll figure out how to best balance this load
/ How to mount a posthole digger #6
This is what I do but I mount the lower U first then the top pole since I have no rops to tie off too. It surprising how light everything is when its in pieces.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
(2) TRAILER RAMPS (A62131)
(2) TRAILER RAMPS...
208735 (A60430)
208735 (A60430)
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
