Siding Screw Up, What would you do?
/ Siding Screw Up, What would you do? #1
HawkinsHollow
SE TN
Branson 3015R
So the crew who did my roofing "also does siding" so I had them give me a quote. I was very impressed by the job they did on my roof and they came in pretty good on the siding quote so I decided to go with them. If had a few week delay on windows but I finally got them in and they started the siding yesterday. Well I get there and they are 75% done but they reveal is a 7" reveal, I wanted it to be a 5" reveal like my garage. This a a Latino crew that seems to be doing an average but far from exemplary job. Their solution was to pull it all down, rip each sheet to 6 1/4 and put it back up, the other option is I just live with it. I chose to just live with it, and I will be asking for a discount on what I pay to make it right.
The reason I chose this option is that I feel like they would have just rushed through it, cut more corners and potentially had the chance of screwing something up even worse in the process. I am torn about my decision. It looks good and most people might not even notice it. The addition has completely different siding than the existing house which has old asbestos siding that we opted to not rip down and replace at this time. We will possibly do that when we replace the old windows in the existing house. Another caveat is the houser next to my house burned down 15 years ago. In the process it melted the side of my house and they replaced the old siding with 7" reveal hardie. So when we do reside the older portion of the house the 7" hardie they put there will keep us from having to redo the newer side.
I have worked VERY hard on this addition and things have been going very smooth. This is the first kick in the pants situation I have had that has kind of upset me and not gone the way I wanted it to. First world problems I know! Oh BOO HOO my brand new 850 sqft addition has a 2" greater reveal than my garage.
Anyway, just venting. What would you have done?
/ Siding Screw Up, What would you do? #2
Don't feel bad. It should have been done correctly, but I think your decision was the right one and for the right reasons. I'd have made the same choice. The other option is to rip a 2" piece and put that at the top, but the reveal will still be different. I've had similar situations, the reveal on my garage door is different from one side to the other. The builder noticed it and mentioned it, but did nothing about it. The quality of construction seems to be an ongoing issue in many threads.
/ Siding Screw Up, What would you do? #3
Not exactly the same situation, but we had an issue with our corner boards when building -- builder and roofer/siding company (same folks, like you) decided 4" corner boards were appropriate without ever asking us. Never having built a house before, we didn't think about it/make sure to specify it up front.
They did provide a quote to cut the installed siding to accomodate wider (6") corner boards, but the risk of damage seemed high -- cutting into the house wrap or sheathing if the depth stop on their saws wasn't set correctly, etc. So we just decided to keep the smaller boards and paint them differently to minimize their appearance.
I think you made the right call. You'd likely end up with worse issues if they pulled all the boards down and ripped them narrower. And 3 months from now you probably won't even think about it.
/ Siding Screw Up, What would you do? #4
30 years ago I would have torn it off and started over. Today I'd simply live with it. Older and wiser? Probably not.
/ Siding Screw Up, What would you do? #5
I would have been concerned about damaging the material if they had taken it down to rip it. I would also have been concerned about how straight they could rip it or whether it would end up looking worse. FWIW
/ Siding Screw Up, What would you do? #6
As a retired contractor and homeowner, you should have made it crystal clear 2 or 3 times to the contractor that you wanted to match the exposure on the other building. If that had been in a signed contract as agreed upon without a doubt we would not be having this discussion.
If it was not agreed upon as above, you assumed and then you are in the wrong.
I told him I wanted it to match the garage. Water under the bridge at this point. Maybe I did not specify well enough.
For the record the main guy in this company speaks excellent English, so I don't think it was a language barrier thing. I think he just assumed we wanted it 7" revveal because thats what they do on 90% of hardie jobs. But as a sub siding a house 7 feet away from a garage done in 5" reveal I think HE should have made sure he knew CRYSTAL CLEAR what I wanted. His defense is that I said at some point I wanted 7". Overall they did an good job, EXCEPT I asked them to paint the cut ends and they totally ignored that request.
So the next question... do you think it is right to ask for a reduction in price tag due to the mix-up?
/ Siding Screw Up, What would you do? #8
Thought Painted ends are a must for hardie.
I thought so too. I would have done that. And I feel like a better crew would have as well, especially with a visually upsetting and micromanaging homeowner (me) asking for it and watching like a hawk. I will go back and make sure I hit any unpainted ends when possible. But yes not ideal.
/ Siding Screw Up, What would you do? #10
Non english speaking workers can provide cheap labor, making the job much more affordable. But you need to be there at the start of the job if not all the way through to ensure you get what you want. I'm sorry you had this trouble but I know the next time you will be onsite to ensure you get what want.
I agree with you 100%. I’m kicking myself for not being onsite at the outset, probably would have saved myself this grief.
But you can only hover so much during the process. It is then left to the over-site of El Jefe at that point. You just hope you get one that is going to make their workers do good work. Like painting the cut ends.
Live and learn!
/ Siding Screw Up, What would you do? #12
Hardie siding is supposed to be painted on all 6 sides. But I’ve never in my entire life seen anyone actually do it that way. I hate the product and I try my hardest to convince customers not to use it. Luckily I only have to warranty it for 1 year and it takes longer than that to fall apart. Even if it doesn’t delaminate and fall apart which it does the maintenance of recalking and repainting is expensive. There’s a siding product that’s a hybrid with vinyl and fiberglass that looks as good as hardie and hold up much better. It doesn’t wrinkle like actual vinyl is prone to doing.
/ Siding Screw Up, What would you do? #13
I worked 35 yrs in many construction trades. I worked residential, commercial, govt housing, flood control, seismic retrofitting, school construction, and large private multi family development. After that I supervised about 200 men in 14 trades at once. The end result was my responsibility and they all needed supervision. I used to call it a daycare center for men. :LOL:
/ Siding Screw Up, What would you do? #14
Did you supply the siding or did the contractor?
Big Dude daycare sounds about right.
In this case whose job is it to make sure they are playing by the rules? mine? Or the guy I’m paying $10,000 to side my house?
/ Siding Screw Up, What would you do? #17
The general contractor ultimately has to answer for everything rather it was his fault it got screwed up or not. I’m assuming you’re doing that role yourself. I think your first plan of expecting a discount and leaving the work alone was fair.
I am serving that role in this case. And I will live with this faux pas the rest of my life.
I’m not going to ask for a 50% discount but I think a bit of reimbursement if fair. If they had to pull it all down and put it back up it would have been an extra day of labor he would have had to pay.
/ Siding Screw Up, What would you do? #19
I'm assuming there was no signed contract. If there was you could just refuse to pay or negociate a discounted price based upon the work not being done per the contract.
But with only a handshake agreement it's your word against the contractors word and you are at the mercy of the contractor when it comes to a discount
/ Siding Screw Up, What would you do? #20
Eh, that is a bad move. He could hit you with a mechanics lien, no need for notice, because he is personally know to the property owner. I would ask for either a discount. Take down and rip every piece jas several issues. One, they going to reinstall, it's probably gonna be in rough shape, a crap ton of labor, ect. If you get maybe 25% off Labor, I'd call that fair.
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
